Suky
Consultation on rate of rtos task execution |
Posted: Wed Jun 17, 2009 8:23 pm |
The value given in this parameter, that indicates really? Since in a simple example I have made I set up a task to run every 2ms, it is the only task, but I check that runs every 1.7 ms. What can be the problem?
The execution time of task is approximately 2us.
Code: | #include <18F2550.h>
#device adc=8
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL3,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rtos(timer=0,minor_cycle=1ms)
#use fast_io(b)
#bit Led0=0xF81.0
#task(rate=2ms,max=5us)
void Tarea1(void);
void main(){
set_tris_b(0x00);
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
Led0=0;
rtos_run ();
void Tarea1(void){
Led0=1;
delay_us(2);
Led0=0;
thanks!
PD:My English is bad ![Rolling Eyes](images/smiles/icon_rolleyes.gif) |
Suky
Re: Consultation on rate of rtos task execution |
Posted: Sat Jun 20, 2009 10:15 am |
Nobody knows whether it should be so, or am I doing something wrong? ![Rolling Eyes](images/smiles/icon_rolleyes.gif) |
Suky
Posted: Sat Jun 20, 2009 1:49 pm |
Thank you for the tip
Best Wishes! |
