Here I am for sharing a problem I have with PIC18F4550.
The problem is that when I try to run a large program (typically 97% of the rom memory) the pic starts changing the values from some eeprom memory positions. If I run a smaller version of the same program (typically 80% of the rom memory) the problem doesn't appear anymore.
The test is the following:
1. I program the pic with all the eeprom memory filled with the same random value.
2. The pic program shows in a display the value from two positions of the eeprom memory.
3. Then I put the pic in my circuitry and turn it on and off some times.
4. After some time it changes the values from the memory. I can see it in the display and when I take the pic out of the circuitry and read the eeprom memory, I see that other memory positions changed.
5. I repeat the procedure with the smaller code... the problem is not observed anymore.
What's stranger is that in my code there's no routines for changing these memory values. I don't have any idea why these values change when I do the tests.
I use the CCS compiler version 4.013.
Is that a compiler problem? Has anybody ever had this sort of problem?
Any help will be very useful.
Thanks.
Otavio Gomes.
Posted: Wed Jun 17, 2009 2:01 pm
That version is known to have various problems (it's a very early version)
so probably no one wants to help you.
otavio_fisica
Different compiler version, same problem
Posted: Wed Jun 17, 2009 2:12 pm
Thanks for your ready answer.
I have just made the same tests with the compiler 4.088 from a friend. The problem still persists. Does anybody have any ideas about this?
Posted: Wed Jun 17, 2009 2:16 pm
Search on the Microchip forum for this:
eeprom corruption
http://www.microchip.com/forums/search.aspx
They might have some answers.
