Setting PWM, must use 'L'?
John5788
PostPosted: Mon Jun 15, 2009 2:10 pm     Reply with quote
I'm looking at some example code and I keep seeing something like this
set_pwm1_duty(256L);
what does that L do for the value?
also, how would I be able to integrate it into a variable? obviously compiling something like
int16 value = 256;
set_pwm1_duty(valueL);
does not work. thanks in advanced.
PostPosted: Mon Jun 15, 2009 2:12 pm     Reply with quote
See this thread and the links in it.
http://www.ccsinfo.com/forum/viewtopic.php?t=17729&start=12
FvM
PostPosted: Mon Jun 15, 2009 2:48 pm     Reply with quote
Whatever meaningful has been said in the linked threads, it doesn't
change the fact that the below lines produce identical code.
set_pwm1_duty(256);
In contrast, this two are different
set_pwm1_duty(255L);
set_pwm1_duty(255);
Unfortunately, also the previous threads have some similar (and also inapproriate) examples.
