evaang2003
change 4 bit to 8 bit lcd code |
Posted: Sun Jun 14, 2009 7:38 pm |
Hi, I'm trying to change the following code to suit my 8 bit lcd.
Can anybody show me?
This is the code using ds1820 to display temperature on 4 bit lcd.
ds1820_2a.c
Reads and displays temperature.
+5--20-|Vdd B0|-21-11-|D0 |
| B1|-22-12-|D1 |
Gnd---8-|Vss B2|-23-13-|D2 |
Gnd--19-|Vss B3|-24-14-|D3 |
6MHz--10-|Xtal B4|-25--6-|EN |
---9-|Xtal B5|-26--4-|RS |
| 16F876 |-1----MCLR
| B6|-26---Clock
| B7|-27---Data
DataIn---11|C0 |
#include < 16F877a.H >
#include < jonsinc.h >
#fuses XT, NOPROTECT, NOPUT, NOWDT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#define DS1820_DATA_IN_PIN PIN_C0
#define DS1820_FET_CONTROL_PIN PIN_C1
#define DS1820_SKIP_ROM 0xCC
#define DS1820_READ_SCRATCHPAD 0xBE
#define DS1820_CONVERT_T 0x44
// LCD STUFF
#define LCD_D0 PIN_B0
#define LCD_D1 PIN_B1
#define LCD_D2 PIN_B2
#define LCD_D3 PIN_B3
#define LCD_EN PIN_B4
#define LCD_RS PIN_B5
#define LINE_1 0x00
#define LINE_2 0x40
#define CLEAR_DISP 0x01
#define DEGREE_SYM 0xdf
#use delay ( clock=4000000 )
#use standard_io ( A )
#use standard_io ( B )
#use standard_io ( C )
void ResetDS1820 ( void );
void WriteDS1820 ( void );
void ReadDS1820 ( void );
void WaitForConversion ( void );
void LCD_Init ( void );
void LCD_SetPosition ( unsigned int cX );
void LCD_PutChar ( unsigned int cX );
void LCD_PutCmd ( unsigned int cX );
void LCD_PulseEnable ( void );
void LCD_SetData ( unsigned int cX );
static char cShiftBit,cDataOut;
static long iTemperature,iDataIn;
void main ( void )
delay_ms ( 200 );
LCD_Init();
LCD_SetPosition ( LINE_1 + 0 );
printf ( LCD_PutChar, "Temperature is" );
while ( TRUE )
ResetDS1820();
cDataOut = DS1820_SKIP_ROM;
WriteDS1820();
cDataOut = DS1820_CONVERT_T;
WriteDS1820();
WaitForConversion();
ResetDS1820();
WriteDS1820();
cDataOut = DS1820_READ_SCRATCHPAD;
WriteDS1820();
ReadDS1820();
iTemperature = iDataIn / 2;
LCD_SetPosition ( LINE_2 + 5 );
printf ( LCD_PutChar, "%lu%cC %lu%cF ", iTemperature, DEGREE_SYM, ( ( 9 * iTemperature ) / 5 ) + 32, DEGREE_SYM );
output_low ( DS1820_DATA_IN_PIN ); // low
delay_us ( 480 ); // reset pulse width
output_float ( DS1820_DATA_IN_PIN ); // high
delay_us ( 480 ); // presence pulse width
void WriteDS1820 ( void ) // ~70uS per bit
for ( cShiftBit = 1; cShiftBit <= 8; ++cShiftBit )
delay_us ( 5 );
output_bit ( DS1820_DATA_IN_PIN, shift_right ( &cDataOut, 1, 0 ) );
delay_us ( 60 );
delay_us ( 5 ); // recovery time between slots
//delay_us ( 200 ); // ???
void ReadDS1820 ( void ) // ~70uS per bit
iDataIn = 0;
for ( cShiftBit = 1; cShiftBit <= 16; ++cShiftBit )
delay_us ( 5 );
delay_us ( 5 );
shift_right ( &iDataIn, 2, input ( DS1820_DATA_IN_PIN ) ); // sample bit
delay_us ( 55 ); // includes recovery time between slots
ResetDS1820(); // terminate remainder of scratchpad register transmission
void WaitForConversion ( void ) // ~70uS per bit
while ( TRUE )
delay_us ( 5 );
delay_us ( 5 );
if ( input ( DS1820_DATA_IN_PIN ) == 1 ) // sample bit
LCD_SetData ( 0x00 );
delay_ms ( 200 ); // wait enough time after Vdd rise
output_low ( LCD_RS );
LCD_SetData ( 0x03 ); // init with specific nibbles to start 4-bit mode
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
LCD_SetData ( 0x02 ); // set 4-bit interface
LCD_PulseEnable(); // send dual nibbles hereafter, MSN first
LCD_PutCmd ( 0x2C ); // function set (all lines, 5x7 characters)
LCD_PutCmd ( 0x0C ); // display ON, cursor off, no blink
LCD_PutCmd ( 0x01 ); // clear display
LCD_PutCmd ( 0x06 ); // entry mode set, increment
// this subroutine works specifically for 4-bit Port A
LCD_SetData ( swap ( cX ) | 0x08 );
LCD_PulseEnable();
LCD_SetData ( swap ( cX ) );
LCD_PulseEnable();
output_high ( LCD_RS );
LCD_SetData ( swap ( cX ) ); // send high nibble
LCD_PulseEnable();
LCD_SetData ( swap ( cX ) ); // send low nibble
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
output_high ( LCD_EN );
delay_us ( 10 );
output_low ( LCD_EN );
delay_ms ( 5 );
output_bit ( LCD_D0, cX & 0x01 );
output_bit ( LCD_D1, cX & 0x02 );
output_bit ( LCD_D2, cX & 0x04 );
output_bit ( LCD_D3, cX & 0x08 );
evaang2003
Posted: Mon Jun 15, 2009 1:44 am |
Well, I use the 8 bit driver and change it into the following code.
However, it can't be compiled. Look at the bold one.
Why?
Quote: |
void main ( void )
char LINE1[]={ "temperature is" };
char LINE2[]={ " %lu%cC %lu%cF ", iTemperature, DEGREE_SYM, ( ( 9 * iTemperature ) / 5 ) + 32, DEGREE_SYM };
delay_ms ( 200 );
lcd_Init();
lcd_display_str(0, LINE1);
while ( TRUE )
ResetDS1820();
WriteDS1820();
WriteDS1820();
ResetDS1820();
WriteDS1820();
WriteDS1820();
ReadDS1820();
lcd_display_str(1, LINE2);
//////////////////////////////////////////////// lcd_write_cmd()
void lcd_write_cmd(int8 cmd)
delay_us(400);
output_low(LCD_RS);
output_low(LCD_RW);
output(LCD_DAT, cmd);
output_high(LCD_E);
delay_us(400);
output_low(LCD_E);
}//end lcd_write_cmd()
/////////////////////////////////////////////// lcd_write_dat()
void lcd_write_dat(int8 dat)
delay_us(400);
output_high(LCD_RS);
output_low(LCD_RW);
output(LCD_DAT, dat);
output_high(LCD_E);
delay_us(400);
output_low(LCD_E);
}//end lcd_write_dat()
//////////////////////////////////////////// lcd_init()
void lcd_init(void)
output_low(LCD_E); // Let LCD E line low
lcd_write_cmd(0x38); // LCD 16x2, 5x7, 8bits data
delay_ms(15);
lcd_write_cmd(0x01); // Clear LCD display
delay_ms(10);
lcd_write_cmd(0x0f); // Open display & current
delay_ms(10);
lcd_write_cmd(0x06); // Window fixed
delay_ms(10);
}//end lcd_init()
///////////////////////////////////////// lcd_display_char()
void lcd_display_char(int8 line, int8 pos, int8 ch)
int8 tmp;
line = (line==0) ? 0 : 1;
pos = (pos >NCHAR_PER_LINE) ? NCHAR_PER_LINE : pos;
tmp = 0x80 + 0x40*line + pos;
lcd_write_cmd(tmp);
lcd_write_dat(ch);
}//end lcd_display_char()
/////////////////////////////////////////// lcd_display_str()
void lcd_display_str(int8 line, char str[])
int8 i;
for(i=0; i<NCHAR_PER_LINE; i++)
lcd_display_char(line, i, ' ');
if(str[i] == '\0') break;
lcd_display_char(line, i, str[i]);
}//end lcd_display_str() |
evaang2003
Posted: Tue Jun 16, 2009 8:28 pm |
well, i have found hd44780 8 bit lcd driver.
however, the program i write do not display text.
can anybody tell me what's wrong?
the main() is the program i wrote while the rest of the fuction is 8 bit driver.
#INCLUDE<16F877a.H>
#include<string.h>
#use delay(clock=40000000)
#include<stdio.h>
#define IR 0
#define DR 1
#define READ 1
#define WRITE 0
#define lcd_2X16
/* Defines the bits for Port C */
struct {
int unused:5; //The first 5 bits are not used by the LCD
int en:1; //EN is the 6th bit of Port C RC5
int rs:1; //RS is the 7th bit of Port C RC6
int rw:1; //RW is the 8th bit of Port C RC7
}LCDControl;
#byte LCDData = 0x08 //Defines the address of the variable LCDData
//as that of Port D
#byte LCDControl = 0x07 //Defines the address of the structure
//LCDControl as that of Port C
#byte LCDDataDir =0x88 //Defines the address of the variable
//LCDDataDir as that of TrisD
#byte LCDConDir = 0x87 //Defines the address of the variable
//LCDConDir as that of TrisC
#define LCD_DATA_IN LCDDataDir|=0xFF //to set the data lines as input
#define LCD_DATA_OUT LCDDataDir&=0x00 //to set the data lines as output
#define LCD_CON_OUT LCDConDir&=0x1F //to set the control lines as output
/************************The WriteByte function *******************/
This function writes a byte to the LCD module with an 8-bit
interface
Input Parameters:
int rs This variable selects the register being written to.
DR selects the data register
IR selects the instruction register
int data_to_lcd This variable stores the data that will be written to
the selected register
void WriteByte(short int rs, int data_to_lcd)
LCD_DATA_OUT; //LCD Data Bus is an output
LCDControl.rw = WRITE; //The operation is a write operation
LCDControl.rs = rs; //Selects the register (DR or IR)
delay_us(1); //Wait a minimum of 60ns
LCDControl.en = 1; //Raise EN
LCDData = data_to_lcd; //Set the Data Bus to the desired value
delay_us(1); //Wait a minimum of 195ns
LCDControl.en = 0; //Clear EN
delay_us(1); //Keep RS and RW at their current states for a
//minimum of 20ns
//Also, keep the current value at the Data Bus
//for a minimum of 10ns
/************************The ReadByte function *******************/
This function reads a byte from the LCD module with an 8-bit
interface
Input Parameters:
int rs This variable selects the register being read from.
Output Value: The function returns the value of the byte read
int ReadByte(short int rs)
int data_from_lcd; //This variable is used to store the byte
//read from the Data Bus
LCD_DATA_IN; //Port D is an input port
LCDControl.rw = READ; //The operation is a read operation
delay_us(1); //Wait a minimum of 360ns
data_from_lcd = LCDData;//Read the value across the Data Bus
//for a minimum of 20ns
return data_from_lcd;
//This function reads the IR register, returning 1 if the LCD module is busy or 0 if it is not
/************************The CheckBusyFlag function ******************/
/* This function reads a byte from the instruction register and
tests the 8th bit, which is the busy Flag
1 if the Busy Flag is set (LCD module busy)
0 if the Busy Flag is clear (LCD module is not
busy)
short int CheckBusyFlag(void)
//read from the LCD
data_from_lcd = ReadByte(IR); //Read the IR (rs=0)
return (bit_test(data_from_lcd,7)); //Test the BF
//Return 1 if set
//Return 0 if clear
/************************The InitLCD function *******************/
/* This function initialises the LCD module (Initialisation by
instruction).
Initialisation Parameters:
Interface 8-bit
Number of display lines 2-line or 4-line
Cursor shift direction Increment
Font size 5x8dots
Display On
Cursor Off
Cursor blink Cursor blink
void InitLCD(void)
delay_ms(15); //Delay a minimum of 15ms
WriteByte(IR,0b00111000); //Define function set
//8-bit interface, 2-line or 4-line display, 5x8 font
delay_ms(5); //Delay a minimum of 4.1ms
WriteByte(IR,0b00111000); //Redefine function set
delay_us(100); //Delay a minimum of 100us
while(CheckBusyFlag()); //Wait until BF = 0
WriteByte(IR,0b00001100); //Define display on/off control
//display on, cursor off, cursor blink off
WriteByte(IR,0b00000001); //Clear Display
WriteByte(IR,0b00000110); //Entry mode set
//cursor direction increment, do not shift display
// WRITING A CHARACTER TO LCD
/************************The WriteChar function *******************/
/* This function displays a character on the LCD.
Input Parameters:
char character This variable stores the character to be displayed on
the LCD.
void WriteChar(char character)
while(CheckBusyFlag()); //Wait until the LCD module is not busy
WriteByte(DR,character);//Write character to DR
// SENDING A COMMAND TO LCD
/************************The PutCommand function *******************/
/* This function writes a byte to the instruction register.
Input Parameters:
int command This variable stores the byte to be written to the
void PutCommand(int command)
WriteByte(IR,command); //Write command to IR
/************************The GoToLine function *******************/
/* This function sets the cursor to the first position of a
specified line of the LCD.
Input Parameters:
int line This variable selects the LCD line on which the
cursor is to be set.
void GoToLine(int line)
int address; //This variable is used to determine the
//address at which the cursor is to be set
switch (line) //Set address to the first DDRAM address of the
//specified line
case 1:
address = 0x00;
case 2:
address = 0x40;
case 3:
address = 0x14;
case 4:
address = 0x54;
default: //An undefined line set the cursor home
address = 0x00;
bit_set(address,7); //Bit 7 identifies the instruction as Set
//DDRAM address
PutCommand(address); //Set the DDRAM address
//WRITING A STRING OF CHARACTERS TO LCD
#define TOTAL_CHARACTERS_OF_LCD 32
void WriteString(char LineOfCharacters[TOTAL_CHARACTERS_OF_LCD])
printf(WriteChar,"%c", LineOfCharacters);
void main ()
char LineOfCharacters[4]={"abc"};
InitLCD();
GoToLine(2);
Posted: Tue Jun 16, 2009 10:21 pm |
Quote: | #INCLUDE<16F877a.H>
#include<string.h>
#include<stdio.h> |
The #fuses statement is missing, and the 16F877A can't run at 40 MHz. |
evaang2003
Posted: Tue Jun 16, 2009 10:27 pm |
well, i have included the
and change the clock to 4 MHz.
However, it still can't run.
Why? |
