Float and constant comparison : what is wrong ?
dynamitron
PostPosted: Sat Jun 13, 2009 9:31 am     Reply with quote
I try to compare a float to a constant (see code below) and I got an error that says that a paren is missing and in fact it is not.
What is wrong ?
Thanks,
D.
float temperature [5];
int8 temperature_haut;
if (temperature [0]>25.0)
     temperature_haut = (int)10 * temperature [0];
Executing: "C:\Program files\Picc\CCSC.exe" +FH "rtc_ow.c" I+="C:\Program Files\PICC\Devices"  +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 58 "rtc_ow.c" Line 799(60,61): Expecting a close paren
*** Error 51 "rtc_ow.c" Line 800(6,7): A numeric expression must appear here
      2 Errors,  0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Sat Jun 13 17:11:08 2009
PostPosted: Sat Jun 13, 2009 10:03 am     Reply with quote
float temperature [0];
You have declared an array with 0 elements. That's not allowed.
It gives this error:
*** Error 45 "pcm_test.c" Line 9(20,21): Subscript out of range
Please get book on the C language.
dynamitron
PostPosted: Sat Jun 13, 2009 10:08 am     Reply with quote
yeah, I know that.
In fact I summarized the code for the post and I made a mistake in the transcript.
The post is corrected now and the question is still there.
D.
PostPosted: Sat Jun 13, 2009 10:14 am     Reply with quote
You're using parens and you should be using braces.
