18F26K20: Serial baud rate wrong, maybe OSC too
Leef_me
PostPosted: Fri Jun 12, 2009 2:29 am     Reply with quote
I have started software design and debugging of a new project and a new (for me) PIC... the 18F26K20.
I am using the ICD-U40 and I can confirm that I am able to d/l code, single step and run a program. I am using PCWH 4.093. I am attempting to use the normal serial port for communications. Unfortunately the baud rate is wrong. For example, if I send a U (0x55) I can measure the lows and highs are about 400us long which is about 2500 baud, instead of the expected 2400.
And the above is at OSC frequency of 8mhz Exclamation
Datasheet says (see below) I should be able to use 1mhz Exclamation Exclamation
I would like to run at 9600 baud, but believe I am either coding something wrong, or the part or compiler is not properly responding to my coding. Per the datasheet, it is supposed to be possible. I am using the internal oscillator.
TABLE 18-5: BAUD RATES FOR ASYNCHRONOUS MODES (CONTINUED)
SYNC = 0, BRGH = 1, BRG16 = 1 or SYNC = 1, BRG16 = 1
FOSC = 1.000 MHz actual rate 9615 %error 0.16 SPBRGH (decimal) 25
Another piece of the puzzle is that, when stopped, the debugging window displays the phrase Ready MCU at 1.00 Mhz.
I am unsure, but I think that frequency should change when I change the OCS value and recompile. It does not.
I have in the main.c
   setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_OFF);
   WHILE (1)
   fputc('+',CONSOLE);
in the man.h file
#include <18F26K20.h>
#device ICD=TRUE
#use delay(clock=8000000)
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=CONSOLE,errors)
Any suggestions/corrections appreciated, thanks in advance.
Leef_me
PostPosted: Fri Jun 12, 2009 12:14 pm     Reply with quote
Try a simple test program like this:
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,ERRORS)
printf("Hello World\n\r");
Also, your posted code has no fuses. The fuses are important.
They tell the compiler how to setup the oscillator registers.
If you have INTRC_IO fuse, the compiler knows that you want to use
the internal oscillator. It also looks at the #use delay() frequency.
With that information, it programs the OSCCON register correctly
in the start-up code.
Let the compiler do it for you.
Leef_me
PostPosted: Fri Jun 12, 2009 4:12 pm     Reply with quote
Thanks PCM, the sample code you provided works fine. Very Happy
I added in the putch 'U' loop, and measured the high and low pulse widths at approx 104us each,
which is the 9615 baud claimed in the datasheet Exclamation
PCM programmer wrote:
If you have INTRC_IO fuse, the compiler knows that you want to use the internal oscillator. It also looks at the #use delay() frequency. With that information, it programs the OSCCON register correctly in the start-up code.
I read in the thread "PIC18F2620 Oscillator configuration"
http://www.ccsinfo.com/forum/viewtopic.php?t=39199
Your comment to Simões, ___ Posted: Wed Jun 10, 2009 2:26 pm
If you have a modern version of the compiler, and if everything is
working correctly with it, then you don't even need a setup_oscillator()
statement. The compiler will look at your fuses and the #use delay()
frequency and it will set up everything correctly.
The thing is that the PIC Wizard put the "setup_oscillator() " in my code, I just changed the OSC_?? value. Rolling Eyes
Thanks again.
Leef_me
PostPosted: Fri Jun 12, 2009 4:17 pm     Reply with quote
You don't need to use everything that the Wizard puts in. It puts in a lot
of lines that disable peripheral modules that are already disabled upon
power-up of the PIC.
Leef_me
PostPosted: Fri Jun 12, 2009 6:28 pm     Reply with quote
Ah yes, now I remember that from times past.
BTW, thanks as well for your patience.
You've probably given similar advice several times before.
And for the next several fellow users who forget to come back and say Eureka & thanks:
Thanks in advance! Smile
Leef_me
