pin timing of 16F887
treitmey
PostPosted: Wed Jun 10, 2009 5:07 pm     Reply with quote
CCS Ver 3.249 18F452/16F887 running at 18.432000MHz
I'm debugging why my LCD isn't working on port A.
Code runs OK with 18F452 but if I swap to 16F887 it doesn't.
Looking at pin A0 with scope the 18F452 makes a 30uS wide signal but the 16F887 is much smaller, 1.4uS. Can anyone tell me why?
#include <18F452.h>
//#include <16F887.h>
#use delay(clock=18432000)
#use rs232(baud=1200,errors,xmit=PIN_C6,rcv=PIN_C7,parity=e,enable=PIN_C5,stream=CIM)
#use rs232(baud=19200,xmit=PIN_D7,invert,stream=DEBUG)
#case
#zero_ram
#define LCD_RS   PIN_A0 //<-- oscope on this pin, other have simular width
#define LCD_E    PIN_A1 //note no RW
#define LCD_DB4  PIN_A2
#define LCD_DB5  PIN_A3
#define LCD_DB6  PIN_A4
#define LCD_DB7  PIN_A5
#include "LCD.c"
//#include "flex_lcd.c"
//======================= Main ==============================
  setup_adc_ports(NO_ANALOGS);
  #define BEEP   PIN_C0
  #define RELAY  PIN_C1
  #define XMTHEN PIN_C5
  output_low(BEEP);
  output_low(RELAY);
  output_low(XMTHEN);//turn off the TX_enable
  //make sure we start with relays not activated
  //===================== STARTUP SCREEN=====================//
  fprintf(DEBUG,"Starting\n\r");
  lcd_init();
  lcd_putc("\fHello There");
  //fprintf(DEBUG,".");
..update ..
Tried a 16F877 and it works,.. but not 16F887
PostPosted: Wed Jun 10, 2009 5:32 pm     Reply with quote
I just installed vs. 3.249 and I can't find the 16F88x files in it.
Did you add the 16F887 by yourself, using the Device Editor ?
treitmey
PostPosted: Thu Jun 11, 2009 7:56 am     Reply with quote
Yes. I used the 16F877A as starting point.. both have 8K words for programming and 256 data eeprom and portA at 5 and trisa at 0x85.
I'll try it again,... I seem to remember guessing at how to do something or another. I'm sure re-doing it will refresh my memory.
treitmey
PostPosted: Thu Jun 11, 2009 12:29 pm     Reply with quote
..update.. still can't fix it.
would a 16F877a hex programed onto the 887 work? at least for port A?
PostPosted: Thu Jun 11, 2009 1:07 pm     Reply with quote
Part of the problem is likely the ANSEL and ANSELH registers in the
16F887. They power-up as all 1's, which sets much of Port A and Port B
as analog pins. If you just defined those register addresses with #byte
statements and then set both registers to 0x00 at the start of main(),
it might cure your problems.
Because you created the 16F887 with the Device Editor, there's no
guarantee that this line is writing to the correct registers. I would
delete this line and do it manually, as I suggested above.
Be aware that many of the built-in functions may not work correctly
with your created version of the 16F887.
treitmey
PostPosted: Thu Jun 11, 2009 1:31 pm     Reply with quote
Got it working. Thanks!
