jjude
My code not work |
Posted: Thu Jun 11, 2009 2:21 am |
This not work, why?
#include <16F526.h>
#device adc=8
#FUSES WDT //Watch Dog Timer
#FUSES INTRC //Internal RC Osc
#FUSES IOSCFS_4 //Internal oscillator 4MHz
#use fast_io(B)
#use fast_io(C)
#define kaasu_pulssi PIN_C3
#define pulssi_on output_high(kaasu_pulssi)
#define pulssi_off output_high(kaasu_pulssi)
set_tris_b(0b000011);
set_tris_c(0b000111);
output_float(PIN_B0);
output_float(PIN_B1);
output_float(PIN_C0);
output_float(PIN_C1);
output_float(PIN_C2);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_wdt(WDT_2304MS);
restart_wdt();
pulssi_off;
pulssi_on;
pulssi_off;
Posted: Thu Jun 11, 2009 2:48 am |
Copy-and-paste error?
Code: | #define pulssi_on output_high(kaasu_pulssi)
#define pulssi_off output_high(kaasu_pulssi) |
jjude
Posted: Thu Jun 11, 2009 3:39 am |
FvM wrote: | Copy-and-paste error?
Ääh - yes, copy paste error, i edit this, but code not work.
Is fuses OK?
Internal oscilator OK?
Code: | #include <16F526.h>
#device adc=8
#FUSES NOWDT //Nowatch Dog Timer
#use fast_io(B)
#use fast_io(C)
#define pulssi_off output_low(kaasu_pulssi)
setup_adc(ADC_OFF);
restart_wdt();
pulssi_off;
pulssi_on;
pulssi_off;
Posted: Thu Jun 11, 2009 5:56 am |
In the following sequence, the set_tris_x() statement is overridden, due to an CCS internal tris-register shadow variable, that isn't updated by set-tris(). It's possibly known behaviour for this type of 16F processor, but I regard it as a PCB bug. The most simple way to avoid the problem is not to use the fast_io option.
Code: | set_tris_c(0b000111);
output_float(PIN_C2); |
With fast_io in effect, you must not mix set_tris_x() and output_float() for a particular port.
Wayne_
Posted: Thu Jun 11, 2009 6:01 am |
You have disabled the watchdog timer in your fuses with NOWDT but you then setup the WDT to fire every 2304MS 2.304 seconds.
You kick the WDT before entering your loop.
BUT
You then turn on the pin, wait 1 sec then turn it off then wait 1 sec (2sec + overhead) the WDT will fire.
Now this will cause the PIC to restart which should repeat the above causing the pin to toggle as you expect, but this is not what you want!
Put restart_wdt() in your loop or don't enable the WDT.
Anyway, what actually happens when you try this code ?
"but code not work" doesn't really help. Does PIN_C3 go high, stay low ?
You have MCLR enabled, what do you have connected to it ? |
jjude
Posted: Thu Jun 11, 2009 6:07 am |
FvM wrote: | In the following sequence, the set_tris_x() statement is overridden, due to an CCS internal tris-register shadow variable, that isn't updated by set-tris(). It's possibly known behaviour for this type of 16F processor, but I regard it as a PCB bug. The most simple way to avoid the problem is not to use the fast_io option.
With fast_io in effect, you must not mix set_tris_x() and output_float() for a particular port. |
Thanks.
I deleting FAST_IO and code run OK.
Is this bug (4.092))? |
