display text on lcd
evaang2003
display text on lcd
PostPosted: Tue Jun 09, 2009 9:24 pm     Reply with quote
Hi, I was trying to display text on lcd lmb162hba.
I try the 4 bit code but it didn't work.
THE CONNECTION IS AS FOLLOW:
pin D0=E
D1=RS
D2=R/W
D4=DB4
D5=DB5
D6=DB6
D7=DB7
The following is the code:
#include<16f877a.h> //HEADER FILE;
#use delay(clock=4000000) //CRYSTAL FREQUENCY IS 20MHZ;
#include  <lcd.c> //LCD DRIVER FILE;
#byte portb=0x06 //SPECIFY PORTB ADDRESS;
#byte trisb=0x86
#byte portd=0x08 //SPECIFY PORTD ADDRESS;
#byte trisd=0x88
main()
lcd_init();
set_tris_d(0x00); //PORTD IS CONFIGURED AS A O/P;
portd=0x00;
    lcd_gotoxy(1,1);
    printf(lcd_putc,"welcome to"); //IN 1ST ROW "welcome to";
    delay_ms(3);
    lcd_gotoxy(1,2);
    printf(lcd_putc,"LCD INTERFACING"); //IN 2ND ROW "LCD INTERFACING";
    delay_ms(3);
Can anybody tell me the 8 bit mode and any wrong with 4 bit code?
PostPosted: Tue Jun 09, 2009 9:52 pm     Reply with quote
Try the Flex driver. It's a 4-bit driver and it should work.
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
Rohit de Sa
PostPosted: Tue Jun 09, 2009 10:06 pm     Reply with quote
First glaring error:
You have a 20MHz crystal - you need to put 'clock=20000000'.
#byte trisb=0x86
#byte trisd=0x88
and
portd=0x00;
You need not put these. The compiler handles I/O direction on its own.
Rohit
evaang2003
PostPosted: Tue Jun 09, 2009 11:03 pm     Reply with quote
erm, i use 4MHz crystal. just wrongly declare as 20MHz.
is it possible that the the lcd i use need to be driven by 8bit?
anybody got 8 bit lcd display text ccs code?
Rohit de Sa
PostPosted: Tue Jun 09, 2009 11:51 pm     Reply with quote
This is the datasheet for the LCD: http://www.topwaydisplay.com/Pub/Manual/LMB162HBC-Manual-Rev0.2.pdf
Page 4 says that it supports 4 bit mode.
Your LCD uses the ST7066U controller, which I believe (after a bit of googling :-) ) is pin and function compatible with the HD44780 controller. The datasheet of the module says that DB0-DB3 can be left NC in 4 bit mode. However, a few online forums mentioned that connecting them high worked in some cases, and grounding them worked in other cases. Maybe you can try that out?
Regarding an 8bit driver, here is something by Nisar Ahmed: http://www.ccsinfo.com/forum/viewtopic.php?t=38367&highlight=8bit
Rohit
evaang2003
PostPosted: Wed Jun 10, 2009 8:17 pm     Reply with quote
i finally know what is the crucial error.
it was actually my compiler that generate rubbish hex code.
i now trying to get the new one.
thanks for everyone that have help me.
