cap110874 Guest
How to implement simple rs232 string receive |
Posted: Mon Jun 08, 2009 10:44 am |
Hi folks,
I am using rs232 (hardware on pic 18f2525) to receive single character commands from a pc.
This works very well but I would like this to work with simple strings if possible so I can change my single character commands to 3 characters.
Any suggestions on how to implement simple strings would be very welcome.
The code I have for single commands is
Code: | void pc_recv_check(void)
char c;
if (kbhit(STREAM_UART))
c = fgetc(STREAM_UART);
if (c=='u')
Drive_Up();
fprintf(STREAM_UART, "Up_Received");
if (c=='d')
Drive_Down();
fprintf(STREAM_UART, "Down_Received");
if (c=='s')
Drive_Stop();
fprintf(STREAM_UART, "Stop_Received");
Posted: Mon Jun 08, 2009 10:51 am |
Look at the get_string() function. It's in this file:
Quote: |
c:\program files\picc\drivers\input.c |
It also has other input functions such as gethex(), get_int(), etc. |
cap110874 Guest
Tring hard but not getting anywhere |
Posted: Tue Jun 09, 2009 5:57 am |
I took a look at the input .c and came up with the following code, but this also doesnt seem to work. Any suggestions would be very welcome. My small brain is aching as I don't understand too much of the c language.
#include <string.h>
char string1[4], string2[4]; // define 2 strings 4 characters long
if (kbhit(STREAM_UART)) // Check to see if there is anything on the UART
strcpy(string2,"fred "); //If there is data set string2 to hold value fred
fgets(string1, STREAM_UART); // get the data from rs232 and place in string1
if(strcmp(string1, string2)) //Compare 2 strings
fprintf(STREAM_UART, "Password_OK\r\n "); //Print ok if they match
fprintf(STREAM_UART, "Password_BAD\r\n "); // Print BAD if they dont match
Wayne_
Posted: Tue Jun 09, 2009 6:08 am |
First of all you have an extra space after fred "fred "
Secondly the STRING "fred" is actually 5 characters long.
Code: | 'f', 'r', 'e', 'd', '\0' |
The '\0' is a null terminating character used to indicate the end of a string. You must allocate space for its storage
char string2[5];
strcpy(string2,"fred"); |
The same for getting a string from your input
Code: | char string1[5];
fgets(string1, STREAM_UART); |
Your next problem is, is it possible for more chars to be entered ?
Is yes then you need to protect against it.
The easiest way is to have a larger buffer
cap110874 Guest
still learning - long way to go i think |
Posted: Tue Jun 09, 2009 6:48 am |
Thank you for your advice. This makes perfect sense when you word it like that. Just having problems getting it to compile.
#include <string.h>
char string1[80], string2[5]; // define 2 strings 4 characters long
char string2[5];
strcpy(string2,('f', 'r', 'e', 'd', '\0')); //If there is data set string2 to hold value fred
char string1[80];
fgets(string1, STREAM_UART); // COMPILE ERROR asking to numeric expression
Posted: Tue Jun 09, 2009 8:17 am |
Includes, in general, _must_ be outside of any function. So:
#include <string.h>
void function(void) {
//your code
Remember an include works as if you type all it's code 'in' at the point you include it. If you put it inside a function, and it contains function definitions, then you will have definitions inside definitions - not legitimate....
mkuang
Re: still learning - long way to go i think |
Posted: Tue Jun 09, 2009 8:43 am |
cap110874 wrote: | Thank you for your advice. This makes perfect sense when you word it like that. Just having problems getting it to compile.
#include <string.h>
char string2[5];
char string1[80];
You declared string2[5] twice, once right after #include <string.h> and then once again after the if(kbhit) statement. You cannot declare variables in the middle of executable code. |
cap110874 Guest
thank you for another bit of very useful knowledge |
Posted: Tue Jun 09, 2009 8:50 am |
Thanks for your help guys. The code seems to be near but I am having problems with it locking up.
It seems to be stuck receiving rs232 because it doesn't pass to the last if statement. I thought this would just timeout after a few ms.
#include <string.h>
char string1[80];//, string2[5]; // define 2 strings 4 characters long
char string2[5];
Wayne_
Posted: Tue Jun 09, 2009 9:43 am |
See comments
#include <string.h> // This at the top of your file somewhere !
strcpy(string2, "fred"); //This will automatically add '\0' to the end of your string and is neater
if(strcmp(string1, string2) == 0) // strcmp returns 0 if they are equal!
Please note fgets reads input until a return is encountered.
If your teminal program appends <cr><lf> (Linefeed) then this may be messing up your input. |
cap110874 Guest
very very close |
Posted: Tue Jun 09, 2009 10:15 am |
Yes your right, the code is now working well with your mods to simplify it.
I changed terminal programs and works well with a CReturn.
If i send CReturn everything works perfectly.
is there any way of stopping the code from locking up until it gets a cr. |
Wayne_
Posted: Wed Jun 10, 2009 2:08 am |
There is a way of stopping it from locking up. You can use the serial interrupt if it is hardware serial or polling if you are using software serial on a non interrupt port.
There are many examples and lots of info on how to do this in this forum so I will not be posting the code for it.
When you have got some code and you are having trouble with it then I am sure plenty of people on here will help you out.
Have fun. |
cap1108742003 Guest
great help guys thank you |
Posted: Wed Jun 10, 2009 10:06 am |
Thanks wayne and everyone else.
Im working on the locking up bit now but its getting very close. Ill post some code once i get it going but may take a few hours yet.
Thankyou all......... |
sri..... Guest
problem with line feed |
Posted: Thu Jul 02, 2009 10:18 pm |
hi friends,
I tried using both get_string and gets. I am getting stuck with the carriage return and line feed combined, the code remains in INT_RDA interrupt all the time.
Please help me.... |
FvM
Posted: Thu Jul 02, 2009 11:28 pm |
I can't imagine, that gets() or get_string() can be a solution for the terminal input interface of typical embedded applications. Basically, because you can't leave the main loop waiting for a carriage return, that may come either next second or next day...
This input method is appropriate for a DOS style terminal application, that can afford to wait for user input, doing nothing else. In the embedded world, you have to read the terminal input to a buffer and start action, when a complete line has been received, indicated by the terminating CR.
There are different ways to achieve this behaviour, personally I prefer to have a interrupt driven circular buffer for UART receive, check this buffer for the terminating CR from the main loop and execute the input function, that extracts and interprets the next line from the buffer, conditionally. I don't want to discuss the details, just mention the general method. |
