Steove Guest
PCF8563.c driver problems, problems with struct |
Posted: Sun Jun 07, 2009 5:19 pm |
Hi all,
I'm a self learning newbie to this game and at the moment stuck on what is probably a simple problem.
I have set up a PIC18F2550 with a LCD and am trying to communicate to a Temp senor and RTC over I2C.
I have no problem with the temp sensor which is working fine, however when I try to read from the RTC using the inbuilt pcf8563 driver I can't find the right code to achieve passing the arguments with. It's using a struct but I can't find any examples no matter how much I search on how to use it.
Please help!!!
In the headder file of pcf8563.c It states to use rtc_get_datetime(TIME_STRUCT *ts) to read the time.
So I use:
My_sec = rtc_get_datetime(TIME_STRUCT.sec)
but I keep getting "Error 54 expecting a variable" when I con to compile.
I have tried all sorts of other options but get nowhere.
I have included my code below:
#include "C:\PICproj\Timecheck.h"
#include "lcd.c"
#include "pcf8563.c"
#use I2C(master, SCL=PIN_B1, SDA=PIN_B0, FORCE_HW)//USE SLOW=40000 IF HAVING PROBLEMS
#define LCD_ENABLE_PIN PIN_C1
#define LCD_RS_PIN PIN_C2
#define LCD_RW_PIN PIN_C0
#define LCD_DATA0 PIN_B4
#define LCD_DATA1 PIN_B5
#define LCD_DATA2 PIN_B6
#define LCD_DATA3 PIN_B7
int data;
int ack;
// RTC variables
unsigned int8 My_year; //years since 2000
unsigned int8 My_month; //1..12
unsigned int8 My_day; //1..31
unsigned int8 My_dow; //0..6
unsigned int8 My_hour; //0..23
unsigned int8 My_min; //0..59
unsigned int8 My_sec; //0..59
//end of RTC clock varibles
int16 adc_value;
float volts;
unsigned int8 time;
set_tris_b(0x03);
set_tris_c(0x00);
lcd_init();
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
//*****initilse the RTC********
i2c_start(); //talk to the RTC
i2c_write(0xA2); //write out the RTC ID
i2c_write(0x00); //write out the control byte
i2c_write(0x00); //write out two 00's
i2c_write( 0x00);
i2c_stop(); //write stop
//******Pulse LED heartbeat
output_high(PIN_A1); //turn heartbeat LED on
delay_ms(100); //wait 100 ms
output_low(PIN_A1); //turn heartbeat LED off
//******Read the Temp sensor
i2c_start(); //talk to the temp sensor
ack = i2c_write(0x90); //write out the senor ID
ack = i2c_write(0x00);
i2c_stop();
/* send start again */
i2c_start();
ack = i2c_write(0x91);
data = i2c_read(0);
i2c_stop();
//******Read the time from the RTC
My_sec = rtc_get_datetime(TIME_STRUCT.sec);
//******Write to LCD
printf(lcd_putc, "\fTime: %u2 \n", My_sec); //LCD first line
printf(lcd_putc, "Temp: %u deg", data); //LCD second line
delay_ms(500); // system delay
If anyone could point me in the right direction it would be most appreciated.
Regards..... |
Steove Guest
Posted: Mon Jun 08, 2009 6:19 am |
Thanks PCM Programmer, once again your knowledge on CCS C has saved many hours.
I looked through the suggested code and realized I was way off track, started from scratch and now have the LCD display showing the time ticking over nicely with only one small issue......
The seconds are counting from 1 - 11, then jumps to 50 - 65 then jumps back to 60 - 75 and finally 70 - 85 but wait, the best of all is that the minutes update when the seconds jump from 11 to 50!!!
I have timed the cycle and it is exactly 60 sec still.
The minutes and hours appear to be updating OK.
Has anyone seen this before??
Once again thanks for the help!! |
Charlie U
Joined: 09 Sep 2003 Posts: 183 Location: Somewhere under water in the Great Lakes
Posted: Mon Jun 08, 2009 7:24 am |
Take a quick look at the data that is returned. If I am not mistaken, the data is in BCD (Binary Coded Decimal) format. You need to handle the high and low nibbles separately. |
Posted: Mon Jun 08, 2009 10:06 am |
Post your current test program. |
Steove Guest
Posted: Mon Jun 08, 2009 2:38 pm |
I agree Charlie, looks to me as its something to do with the way the BCD is handled, but I cant find it (its all handled within the pcf device driver.
Here's my current code, its much cleaner now thanks to PCM programmer....
#include "C:\PICproj\Temp.h"
#include <lcd.c>
#include <pcf8563.c>
TIME_STRUCT ts;
lcd_init();
rtc_init();
lcd_putc("\fReady...\n");
while (TRUE) {
rtc_get_datetime(&ts);
printf(lcd_putc, "\fTime: %u:%u:%u \n", ts.hour, ts.min, ts.sec); //LCD first line
printf(lcd_putc, "Temp: %u deg", 20); //LCD second line
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// TODO: USER CODE!!
Posted: Mon Jun 08, 2009 2:56 pm |
Where is the line of code to initialize the RTC chip to a date and time ? |
Steove Guest
Posted: Mon Jun 08, 2009 10:56 pm |
In this test code I haven't gone to the trouble of setting the time yet, this was the next step after being able to read from the RTC accurately.
Will this have an effect on the registers counting normally???
What does Confucius say.
Even though the journey takes many months.... it must start with one single step...... :-)
Personally, I think I will be tripping up and falling more than the steps themselves.
Thanks for your help. |
Posted: Mon Jun 08, 2009 11:21 pm |
You should initialize the registers to a known value and then determine
if it's working properly. |
Steove Guest
Posted: Tue Jun 09, 2009 7:17 am |
All Fixed!!!
It turned out that there was a bug in the PCF8563 driver, during reading the seconds it effectively performed a double "BCD to Decimal" conversion.
I don't know if this is fixed in the later versions of CCS C, this may need to be checked.
The incorrect code was as below:
void rtc_get_datetime(TIME_STRUCT *pTs)
TIME_STRUCT ts;
int8 val;
i2c_start(STREAM_PCF8563);
i2c_write(STREAM_PCF8563, PCF8563_I2C_ADDR);
i2c_write(STREAM_PCF8563, PCF8563_SECONDS);
i2c_start(STREAM_PCF8563, 2);
i2c_write(STREAM_PCF8563, PCF8563_I2C_ADDR | 1);
val = _rm_bcd(i2c_read(STREAM_PCF8563, 1));
//ts.valid = !bit_test(val, 7);
ts.sec = _rm_bcd(val & 0x7F);
ts.min = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x7F);
ts.hour = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x3F);
ts.day = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x3F);
ts.dow = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x07);
ts.month = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x1F);
ts.year = _rm_bcd(i2c_read(STREAM_PCF8563, 0));
i2c_stop(STREAM_PCF8563);
memcpy(pTs, &ts, sizeof(ts));
I replaced the offending code with:
ts.sec = _rm_bcd(i2c_read(STREAM_PCF8563, 1) & 0x7F);
Thanks for all the help.
Onwards to the rest of the project.......... |
Posted: Tue Jun 09, 2009 12:23 pm |
The bug is still there in vs. 4.093. You should email CCS tech support
about it. Tell me if you want to do it. If not, I'll do it. |
Steove Guest
Posted: Tue Jun 09, 2009 3:36 pm |
Thanks PCM.
I send a bug report in now, I have an older version, so if you don't mind I'll mention that you have checked 4.093 and it's still there.
Cheers. |
