fprintf/fgets
Alex
fprintf/fgets
PostPosted: Mon Jun 08, 2009 4:28 am     Reply with quote
I'm a bit confused. I've found a topic that says that fprintf uses interrupt routine and 64bytes buffer to send a string.
And as I understand fputs will just halt everything until string transmitted.
So how do receive functions work? (gets/fgets)
Do they use an interrupt routine as well or not?
Thank you.
PostPosted: Mon Jun 08, 2009 5:12 am     Reply with quote
It sounds as if you are taking the 'topic' out of context.
None of the CCS routines use interrupt functions 'out of the box'. Printf, _can_ use a buffered interrupt driven routine, by using something like ex_stisr, and telling printf to use this as it's output routine.
The USB putc/getc routines, are buffered by default.
Alex
PostPosted: Mon Jun 08, 2009 5:28 am     Reply with quote
Thank you.
