Compiler problems - Access violation
uni_student
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sat Jun 06, 2009 4:55 am     Reply with quote
Have no idea what i have done, but every time i now open a c file it comes up with a dialog box saying "File not Found". It does open the file after closing the box and when i want to compile my program it comes up with an error "Access violation at address 00660957 in module 'pcw.exe'. Read of address 00000000."
Any ideas what is wrong? Any help appreciated!
PostPosted: Sat Jun 06, 2009 11:59 am     Reply with quote
Re-install the compiler.
uni_student
PostPosted: Sat Jun 06, 2009 3:57 pm     Reply with quote
Re-installing has fixed the latter problem. Still "File not Found" message comes up, it will do for now.
apcaye
PostPosted: Tue Jun 09, 2009 6:54 am     Reply with quote
To fix the first problem, I would suggest you to delete your current project workspace file and create a new one, using the Project Wizard if you are using MPLAB IDE. Check that all your project source files are in the same directory and that you have used the correct path in #include directives and in the Project - Build Options.
Regards,
Adriano.
