Help with RS485 communication between two pics
mkuang
PostPosted: Wed Jun 03, 2009 8:33 am     Reply with quote
I am trying to get two pic18f2525 two talk over a rs485 interface. Each pic is on a separate pcb and each board has a MAX487 RS485 transceiver. Right now I am just trying to establish some sort of one way communication and it is not working. I have created a test program so that pic1 simply sends a character every second based on which one of two RB switches are activated. The code for PIC 1 looks like this:
#include <18F2525.h>
#device ADC=10  //set for 10 bit A/D
#fuses INTRC_IO,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#define NORMAL_OP          1
#define CAL                2
#define FAIL             3
#define OFFLINE          4
#define OFFLINE_RST_SW_ACT      1
#define ZERO_SPAN_SW_ACT         2
#define EXMO_NO_SW         7
#define EXMO_CAL_SW         8
#define EXMO_RST_SW         9
#define SENSOR_ZERO_HIGH_BYTE_ADDX 10
#define SENSOR_ZERO_LOW_BYTE_ADDX 11
#define SENSOR_SPAN_HIGH_BYTE_ADDX 20
#define SENSOR_SPAN_LOW_BYTE_ADDX 21
#define NUM_MSG_NORMAL_OP 3
#define ZERO_SPAN_SW       PIN_B5
#define OFFLINE_RESET_SW    PIN_B4
#define SENSPOT_CS PIN_B3
#define DE_RE   PIN_B0
#define DEBUG1
#define SPI_MODE_0_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_0_1  (SPI_L_TO_H)
#define SPI_MODE_1_0  (SPI_H_TO_L)
#define SPI_MODE_1_1  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
unsigned char exmo_sw=4;
#include <sce5774.c>
#INT_RB
void rb_isr(void)
 if (input(OFFLINE_RESET_SW) == 0)
   exmo_sw = EXMO_RST_SW;
 }// if (input(OFFLINE_RESET_SW) == 0)
else if ( input(ZERO_SPAN_SW) == 0)//else zero_span switch activated
         exmo_sw = EXMO_CAL_SW;
} //end void rb_isr(void)
output_low(DE_RE);
reset_display();
setup_spi(SPI_MASTER | SPI_MODE_0_0 |SPI_CLK_DIV_4);
SETUP_ADC_PORTS(AN0_TO_AN2 | VSS_VREF);
setup_adc(ADC_CLOCK_DIV_4 |ADC_TAD_MUL_4 );
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_4, 255, 1);
clear_interrupt(INT_RB);
enable_interrupts(INT_RB);
while (1)
                output_high(DE_RE);
   printf("\n%u\r," exmo_sw);
   output_low(DE_re);
And this appears to be doing what it is suppose to do. I took a peek using hyperterminal and see that it is printing 4 to start and when I activate one of the switches, the RB interrupt causes it to print 8 or 9 as it should.
The receiving PIC code looks like:
#define NORMAL_OP          1
#define CAL                2
#define FAIL             3
#define OFFLINE          4
#define DEBUG1
unsigned char ch;
output_low(DE_RE);
reset_display();
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);
setup_ccp1(CCP_PWM);    // Configure CCP2 as a PWMDAC
while (1)
if (kbhit())
   ch = getch();
    // format_adc_to_display(ch);
}//if (kbhit())
ch = 49;
clear_display();
}//while
}//main
The problem is that the receiving pic only grabs the first tranmission on power up and after that it always prints 49 as the value for ch meaning that kbhit() is false.
Anyone has any ideas what the problem might be?
Thanks.
MK
PostPosted: Wed Jun 03, 2009 11:13 am     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=38128
mkuang
PostPosted: Wed Jun 03, 2009 12:12 pm     Reply with quote
Following the link you gave I added 1.2k pullup and pulldown on the A and B lines of the RS485 and a 120Ohm between the A and B. I got the same result. That is: I power up both boards and the receiving pic gets the correct character, once, but then doesn't get any subsequent transmissions. Furthermore if I add the line
format_adc_to_display(kbhit())
instead of
I see that kbhit is always zero on my display. I put a scope probe right on the the Rx pin (RC7) of the receiving pic and I do see 0/5V signals that idle high. So for some reason the pic doesn't think there are bytes coming in.
PostPosted: Wed Jun 03, 2009 12:32 pm     Reply with quote
Why don't you edit the #use rs232() statement, and add the ENABLE
parameter, and specify your DE pin there. And then, remove the
manual DE control statements in your code. Let the CCS library code
handle the RS-485 enable pin. Do this in your transmitter PIC program.
mkuang
PostPosted: Wed Jun 03, 2009 12:44 pm     Reply with quote
I did that and same thing. I stripped away all the unnecessary stuff in the code and now the TX PIC code is:
#device ADC=10
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ENABLE = PIN_B0)
unsigned char exmo_sw=3; //assign ch dummy value to start
#INT_RB
void rb_isr(void)
while (1)
   printf("\n%u\r," exmo_sw); //only talk when receive a '$' from main bd.
}//while
}//main
And the receiving PIC code is:
unsigned char j;
unsigned char ch = 99;
unsigned char messages[3][22] = {
      ">>>PPM>=>>>>>>>>>>>>>",
      ">>DEGC>=>>>>>>>>>>>>>",
      ">STATE>=>>>>>>>>>>>>>"};
#include <string.h>
output_low(DE_RE);
reset_display();
set_brightness(0b11110110);
while (1)
if (kbhit())
   ch = getch();
}//if (kbhit())
ch = 49;
}//while
}//main
Humberto
PostPosted: Wed Jun 03, 2009 12:48 pm     Reply with quote
Being a two point communication it is not necesary any pull up/down resistors. The most obvious problem you have is the DE_RE pins handling as pointed by PCM Programmer.
Let the compiler to do its job, use the ENABLE option (see #use RS232 option in the CCS Compiler Manual )
http://www.ccsinfo.com/forum/viewtopic.php?t=33914&highlight=rs485
http://www.ccsinfo.com/forum/viewtopic.php?t=30630&highlight=rs485
Humberto
PostPosted: Wed Jun 03, 2009 12:50 pm     Reply with quote
You haven't stripped it down enough. Get rid of all the #int_rb stuff
and all the SPI stuff.
You have this huge delay of 500ms in your receiver loop. This prevents
incoming characters from being read from the UART. If you get more
than 2 chars in the UART, it will lock up the receiver. Get rid of that
delay, and also add the ERRORS parameter to the #use rs232()
statement in the receiver PIC code (and transmitter, too). This will
automatically clear an overrun errors that occur.
mkuang
PostPosted: Wed Jun 03, 2009 1:26 pm     Reply with quote
Okay, I think this is as bare as it can be. For the TX:
#device ADC=10
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ENABLE = PIN_B0, ERRORS)
while (1)
}//while
}//main
And for the RX:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#define TEST_PIN         PIN_B2
output_low(DE_RE);
while (1)
if (kbhit())
   ch = getch();
      output_low(TEST_PIN);
}//if (kbhit())
ch = 49;
output_high(TEST_PIN);
}//while
}//main
So now if kbhit is true then my TEST_PIN is low and if kbhit is false then TEST_PIN is high. And I always see TEST_PIN high.
PostPosted: Wed Jun 03, 2009 1:45 pm     Reply with quote
With that loop, it will only go low for a few usec, before it goes high again.
You might not see it.
A better test would be to toggle the pin every time you get a character:
int8 ch;
   ch = getch();
   output_toggle(TEST_PIN);
Or, more simple than that, simply wait until you get a character.
Then set the pin high.
int8 ch;
ch = getch();  // Wait for a char
mkuang
PostPosted: Wed Jun 03, 2009 3:03 pm     Reply with quote
Looks like one of the MAX487 chips has gone bonkers on me. I used another bd as the RX and it appears to work with the test programs, I see the testpin toggle using the first code you suggested.
Thanks.
mkuang
PostPosted: Wed Jun 03, 2009 3:36 pm     Reply with quote
PCM Programmer, with regards to this test program:
int8 ch;
   ch = getch();
How long does the PIC wait to get a character with the getch() function before timing out? Can I assume that if it reaches the output_toggle() then it has received a character? On the scope the testpin is low most of time and goes high for about 1.25 ms at a time.
PostPosted: Wed Jun 03, 2009 3:41 pm     Reply with quote
It never times out. It waits forever, if necessary.
mkuang
PostPosted: Thu Jun 04, 2009 9:58 am     Reply with quote
Thanks PCM Programmer. I modified the test programs slightly so that PIC1 talks, PIC2 waits using kbhit, then look for the character 'E' in the message, and then grab the character after the E and send that out via the printf. So essentially the two pics take turns talking on the RS485 line so there is no bus conflict. So for the the TX pic:
#device ADC=10
unsigned char exmo_sw=4; //assign ch dummy value to start
while (1)
   printf("\nE%u", exmo_sw);
}//while
}//main
And for the RX pic (which answers)
int8 ch;
if (kbhit())
   ch = getch();
   if (ch == 'E')
   ch = getchar();
   printf("\nI received %c", ch);
And I see in hyperterminal:
I received 4
4
I received 4
