Multiple compilation units don't link after upgrading PCM
TopLoser
PostPosted: Tue May 05, 2009 2:59 am     Reply with quote
I have several projects that consist of multiple C files that used to compile and link just fine using 4.085 version of the PCM compiler. Each module has an
#EXPORT (FILE=filename)
directive at the start. The compiler used to compile each module without error and then did a final link phase at the end to link all the .O files together and create a .HEX file.
Version 4.092 seems to behave in a different way. It still compiles each modules without error, but the final link produces a 'Not found' error when it tries to create the .HEX file. All the .O files are present, it's just the link part that fails.
"C:\Program files\Picc\CCSC.exe" +FM LINK="Converter.hex=ec1.o,ec2.o,main.o,timer.o,eeprom.o" +DF +LN +T +A +M +Z +Y=9 +EA
The above line produces the error message
Not found - Converter
All the .O files exists, the compilation part went ok.
I've reported this is CCS but haven't had any response for over a week so here I am asking for ideas...
Had the same problem
PostPosted: Wed Jun 03, 2009 8:21 am     Reply with quote
I had the same problem.
I did the following:
-creating a text file
-rename it to the hexfile name
Build all --> hex file was there
armond
Compiler
PostPosted: Wed Jun 03, 2009 9:05 am     Reply with quote
I have a similar problem. Code I wrote in 4.087 worked fine. After I upgraded to 4.090 or later the code stopped working. I had/has something to do with arrays and if statements..it works fine in mplab, but wont work compiled. So for now Im using 4.087 with no problem..
