Problem in analog comparator in 16f887
world
PostPosted: Wed Jun 03, 2009 2:04 am     Reply with quote
I'm using Pic 16f887.
setup_adc_ports(NO_ANALOGS);
setup_comparator(A0_A1_OUT_ON_A3);
// TODO: USER CODE!!
if(c1out==1)
   output_high (pin_c7);
   output_low (pin_c7);
After compiling an error occured: undefined identifier A0_A1_OUT_ON_A3
I'm new to CCS. Pls anyone help me out.
PostPosted: Wed Jun 03, 2009 11:32 am     Reply with quote
Look in the .H file for your PIC, to see the allowable constants for the
CCS functions. Here's the file location:
c:\Program Files\picc\Devices\16f887.h
world
PostPosted: Thu Jun 04, 2009 12:49 am     Reply with quote
ya i have already looked hex file what constant used for comparator module by seeing that i include then i compiled but once again the same error occured pls help me out.....
thanks in advance
PostPosted: Thu Jun 04, 2009 1:58 am     Reply with quote
I don't mean the HEX file. I mean the 16F887.H file.
Post your compiler version.
world
PostPosted: Thu Jun 04, 2009 2:08 am     Reply with quote
ya i saw 16f887.h file what constant used i changed but also same error occured ......
my compiler version is 4.033
thanks in advance
PostPosted: Thu Jun 04, 2009 2:19 am     Reply with quote
I just installed vs. 4.033 and that constant is not in the 16F887.h file.
The constants that set the input and output configuration all begin
with CP1_ or CP2_.
You should use constants from the 16F887.h file. Get rid of that one
and look in the file to find the correct constant.
world
PostPosted: Thu Jun 04, 2009 2:29 am     Reply with quote
setup comparator(CP1_A0_A1_CP1_OUT_ON_A2);
ya i changed it the same error is occuredd
thanks in advance
PostPosted: Thu Jun 04, 2009 2:36 am     Reply with quote
You cannot tack constants together with an underscore. That's not C.
They have to be combined with the bitwise 'OR' symbol, which is '|'.
Please learn the C language. Get a book on it.
world
PostPosted: Thu Jun 04, 2009 2:50 am     Reply with quote
ok i'll learn it.......
setup_comparator(cp1_a0_a1||cp1_out_on_a2);
is it correct now.......
can u give me good c books for begineer
PostPosted: Thu Jun 04, 2009 3:15 am     Reply with quote
I told you to use bitwise OR, and gave you the symbol. You changed it to
a Logical OR symbol. You cannot write programs and have them work
if you do things in an inaccurate way.
I don't want to help you any more until you fix this problem, where you
"invent" a solution as you go along.
world
PostPosted: Thu Jun 04, 2009 4:47 am     Reply with quote
oh sorry........i typed wrongly it seems. very sorry.........
code built sucessfully not working now
PostPosted: Thu Jun 04, 2009 4:34 pm     Reply with quote
Can u give me good c books for beginner
Threads on books:
http://www.ccsinfo.com/forum/viewtopic.php?t=33272
http://www.ccsinfo.com/forum/viewtopic.php?t=33816
Here are some online C tutorials:
http://www.cs.cf.ac.uk/Dave/C/node4.html
http://cslibrary.stanford.edu/101/EssentialC.pdf
Development tools:
http://www.ccsinfo.com/forum/viewtopic.php?t=26954
