pardal
PIC18F2550 at 48MHz |
Posted: Tue Jun 02, 2009 6:38 am |
Hi! I'd like do program my PIC ECU to run at 48MHz using a 8MHz crystal. The device is a USB HID class and it is working well, but the CPU is running at 8MHz. That's the configuration bits:
Code: | #FUSES NOWDT //No Watch Dog Timer
#FUSES HSPLL //Crystal/Resonator with PLL enabled ok
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES VREGEN //USB voltage regulator enabled
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES BBSIZ2K //2K words Boot Block size
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES PLL2 //Divide By 2(8MHz oscillator input) ok
#FUSES USBDIV //USB clock source comes from PLL divide by 2 ok
#FUSES CPUDIV1 //No System Clock Postscaler |
Why does it running at 8MHz instead 48MHz? |
Posted: Tue Jun 02, 2009 8:23 am |
How are you actually 'proving' the device is at 8MHz?
Is this a standalone chip, or an ICD board (though you have debug disabled, some people use 'third party' tools to perform ICD)?
Do you have a 'setup_oscillator' line in your code anywhere?
What compiler version?
Show your clock setup line.
Posted: Tue Jun 02, 2009 8:57 am |
Quote: | How are you actually 'proving' the device is at 8MHz? |
I show time in sec in a lcd display using TIMER1. I've to configure the timer based on 8MHz clock ( crystal value ) to count correctly.
Quote: | Is this a standalone chip, or an ICD board (though you have debug disabled, some people use 'third party' tools to perform ICD)? |
it's a stand alone chip, mounted in a custom board.
Quote: | Do you have a 'setup_oscillator' line in your code anywhere? | I don't.
thanks for the help! |
pardal
Posted: Tue Jun 02, 2009 8:59 am |
Anonymous wrote: | How are you actually 'proving' the device is at 8MHz?.
I show time in sec in a lcd display using TIMER1. I've to configure the timer based on 8MHz clock ( crystal value ) to count correctly.]
Is this a standalone chip, or an ICD board (though you have debug disabled, some people use 'third party' tools to perform ICD)?.
Do you have a 'setup_oscillator' line in yout code anywhere?.
I don't.
it's my post! ![Laughing](images/smiles/icon_lol.gif) |
Posted: Tue Jun 02, 2009 11:58 am |
This test program blinks the LED on pin B0 at a 1 Hz rate. This means
it's running at 48 MHz. An 8 MHz crystal was used. This was tested
with vs. 4.093.
Code: | #include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,USBDIV,PLL2,CPUDIV1
#use delay(clock=48000000)
output_high(PIN_B0);
output_low(PIN_B0);
If it doesn't work for you, then post your compiler version. |
pardal
Posted: Tue Jun 02, 2009 1:21 pm |
PCM programmer wrote: | This test program blinks the LED on pin B0 at a 1 Hz rate. This means
with vs. 4.093.
output_low(PIN_B0);
It doesn't work! my CCS version is 4.068 |
Posted: Tue Jun 02, 2009 1:47 pm |
Quote: | It doesn't work! my CCS version is 4.068 |
I installed vs. 4.068 and compiled it and downloaded it to a 18F4550
on a PicDem2-Plus board. It works. I then compiled it for the 18F2550
and compared the .LST files. They have the same code.
Explain what you mean by "It doesn't work". |
Posted: Tue Jun 02, 2009 3:09 pm |
If it wasn't for the USB apparently working, I'd be very suspicious there was a problem with the primary oscillator. In the original fuses, the 'fail safe' oscillator options are enabled, without PUT, which will almost certainly result in the initial startup being at 8MHz. If there was something wrong wth the primary oscillator, it'd probably drop back to 8MHz as well. If there was a fault with the primary oscillator, then PCM's test code, would not run.
pardal
Posted: Wed Jun 03, 2009 7:08 am |
PCM programmer wrote: | Quote: | It doesn't work! my CCS version is 4.068 |
CPU clock doesn't work at 48MHz. I'm testing the firmware with Proteus 7.5 . USB connection works well, but CPU clock is still 8MHz! |
pardal
Posted: Wed Jun 03, 2009 7:14 am |
Ttelmah wrote: | If it wasn't for the USB apparently working, I'd be very suspicious there was a problem with the primary oscillator. In the original fuses, the 'fail safe' oscillator options are enabled, without PUT, which will almost certainly result in the initial startup being at 8MHz. If there was something wrong wth the primary oscillator, it'd probably drop back to 8MHz as well. If there was a fault with the primary oscillator, then PCM's test code, would not run.
USB work well. I have had a similar problem on a MSP430 (Texas instrument ) uC. A failure in the system clock switches to other oscillator, running at 32kHz. PIC18 system clock is a new to me. If a failure happens, the clock switches? |
Posted: Wed Jun 03, 2009 9:01 am |
Quote: | I'm testing the firmware with Proteus 7.5 . |
I'm testing with real hardware. |
Posted: Thu Jun 04, 2009 8:04 am |
PCM programmer wrote: | Quote: | I'm testing the firmware with Proteus 7.5 . |
I've had already tested it in a PCB, doing leds to blink and it showed the same behavior of simulation on Proteus! |
Posted: Thu Jun 04, 2009 11:46 am |
Have you tested my exact program for LED blinking that I posted ?
Tested it in hardware, with no other external circuits (USB, etc). |
