yet another adc problem...
rubber
PostPosted: Thu May 28, 2009 2:03 pm     Reply with quote
Hi!
I'm trying to read a voltage divider made by a 22k potentiometer.
pin1 of the pot goes to vcc, pin3 to vss and center pin on the pic16f877a.
I wrote this code, but seems like there's something wrong because it's not working.
#include <16F877A.h>
#device ADC=8
#include <math.h>
#include <stdlib.h>
#include <string.h>
#fuses  XT, NOWDT, PUT, NOPROTECT, NOBROWNOUT, NOLVP, WRT_50%, NOCPD
#use delay(clock=11059200)
#use rs232 (baud= 9600,xmit=PIN_B6, rcv=PIN_B7, INVERT)
int16 posicao;
void init(void)
setup_adc_ports( AN0 );
int16 converte_adc()
int16 adc;
      delay_us(10);
      set_adc_channel( 0 );
      adc = read_adc();
      return adc;
printf("ola!!!!");
init();
printf("ola!!!!");
   while(1){
      //posicao=converte_adc();
      posicao=(float)converte_adc();
      posicao=((posicao/255.0)*5.0);
      delay_us(100);
      printf("\n posicao %ld\n\n\r",posicao);
Any ideas?
Thanks in advance.
RJ
PostPosted: Thu May 28, 2009 2:25 pm     Reply with quote
Look in the oscillator section of the PIC data sheet. XT mode is only
recommended for crystals of 4 MHz, maximum. It doesn't have the
power to drive a faster crystal. Use HS mode.
Also, there's no reason to use write protection during development of
an A/D program.
