Converting ASCII characters to values....
PostPosted: Tue May 26, 2009 9:11 pm     Reply with quote
Hi All,
I'm transmitting ASCII characters to my PIC via the UART. These characters represent hex bytes, such as 'CF' or 'DE', etc. Is there an compact, easy way to convert these character pairs into a numeric value? I can think of a few brute force methods (Case statements, etc), but nothing elegant...
Suggestions welcome!
Charlie
PostPosted: Tue May 26, 2009 9:32 pm     Reply with quote
Look at the atoi_b16() function in the CCS loader.c file:
c:\program files\picc\drivers\loader.c
Here is the axtoi() function:
http://www.ccsinfo.com/forum/viewtopic.php?t=35175&start=2
It's a version of atoi() which expects hex characters.
A reason for using axtoi() instead of atoi():
http://www.ccsinfo.com/forum/viewtopic.php?t=28088
Look at the functions in input.c, which allow you to get hex digits, longs,
and floats from the PC:
c:\program files\picc\drivers\input.c
Look at the many functions in stdlib.c, such as strtol, strtoul, etc.
c:\program files\picc\drivers\stdlib.h
Look in the CCS manual in this section for a list of these functions:
STANDARD
C CHAR /
STRING
Possibly use Google to find better and longer explanations than are
given in the CCS manual.
PostPosted: Wed May 27, 2009 3:33 pm     Reply with quote
Hi PCM,
Thanks for the pointers. Actually, the job was simpler than I imagined. Here is the routine I wrote based on your earlier work. It seems to perform just fine.
int AsciiToHex(char Digit)
//This routine takes an uppercase ASCII hex character (0 - 9) and (A - F) and converts
//the character to a binary representation.
    //Here we check if the char is an ASCII hex char
   if ((Digit < '0') || (Digit > 'F') || ((Digit < 'A') && (Digit > '9')))
   //Here we convert the ASCII hex char to binary and return the value
   Digit -= 0x30;
    if(Digit > 9)
       Digit -= 7;
   return(Digit);
And, I use it like this:
MUX0 = (AsciiToHex(RxBuffer[5]) * 16) + (AsciiToHex(RxBuffer[6]));
Do you see anything wrong with this implementation?
Thanks,
Charlie
