Uart stream - solved
jaime
PostPosted: Mon May 25, 2009 3:13 pm     Reply with quote
Hello
I'm testing the fat driver from ccs with 4.072 compiler. Everything works with one uart, but when I change my code for two uarts and add a stream for each one I have some compiler error.
undefined identifier pc
Can anyone explain this?
#include <18F2525.h>
#device PASS_STRINGS = IN_RAM
#fuses NOWDT,HS, NOPROTECT
#use delay(clock=16M)
#use rs232(baud=57600, xmit=pin_b6, rcv=pin_b7, errors, stream=pc)
#use rs232(baud=4800, xmit=pin_c6, rcv=pin_c7, errors, stream=gps)
#define MMCSD_PIN_SCL     PIN_A1 //o
#define MMCSD_PIN_SDI     PIN_A3 //i
#define MMCSD_PIN_SDO     PIN_A2 //o
#define MMCSD_PIN_SELECT  PIN_A0 //o
#include <mmcsd.c>
#include <fat.c>
int i;
char file_name[20];
char buffer[255];
FILE stream_file;
strcpy(file_name,"/log.txt");
delay_ms(3000);
fprintf(pc,"\r\nINIT: ");
i = fat_init();
if (i)
   fprintf(pc,"ERROR INITIALIZING FAT");
   fprintf(pc,"INIT OK");
fprintf(pc,"\r\nMAKING FILE '%s': ", file_name);
if(mk_file(file_name) != GOODEC)   //??????????????
   fprintf(pc,"ERROR CREATING FILE");
   fprintf(pc,"FILE CREATED");
fprintf(pc,"\r\nWRITE SOMETHING : ");
   do{
      buffer[i] = getch();
      // check for a backspace
      if(buffer[i] != 8)
         fprintf(pc,"%c", buffer[i]);
         i++;
      else if(i > 0)
         // delete the last character
         i--;
         putc(8);
         putc(' ');
         putc(8);
      }while(buffer[i - 1] != '\r');
   buffer[i-1] = '\0';
   fprintf(pc,"\r\nAPPENDING '%s' TO '%s':", buffer, file_name);
   if(fatopen(file_name, "a", &stream_file) != GOODEC)
      fprintf(pc,"\n\rERROR OPENING FILE");
      fprintf(pc,"\n\rOPEN OK");
   fatputs(buffer, &stream_file);
   fatputs("\r\n", &stream_file);
   if(fatclose(&stream_file) != GOODEC)
      fprintf(pc,"\n\rERROR CLOSING FILE");
      fprintf(pc,"\n\rCLOSING OK");
   i=0;
PostPosted: Mon May 25, 2009 3:36 pm     Reply with quote
It works for me if I change 'pc' to upper case: PC
Do that in the #use statement and in all the functions that call it.
jaime
PostPosted: Tue May 26, 2009 1:40 am     Reply with quote
OK. It works
thanks
