SPI on 16F690 - Wizard bug
bungee-
PostPosted: Thu May 21, 2009 4:35 pm     Reply with quote
Hi!
I have a question and an answer. I use PCWHD v 4.084.
With the PICWizard I have created new project and in the project I'm using SPI communication. To this point everything is OK. But when I configured everything like it should be, I got this code:
#use delay(clock=8000000)
#define SPI_CLK   PIN_C3
#define SPI_DI   PIN_C4
#define SPI_DO   PIN_C5
void setup()
   setup_adc(ADC_OFF);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
In the wizard I selected the option to name the ports .... and one very strange thing happened. Pins that were defined as SPI pins were wrong according to the PIC datasheet.
So I was confused and I simply write the code to constantly send some bytes to the SPI and measured with the scope on the pins.
Result was, that datasheet is correct and CCS actually sends data and clock using correct pins. Wizard defines wrong pins. Rolling Eyes
So for anybody who will be doing same on this combination .... the correct pins are:
#define SPI_CLK   PIN_B6
#define SPI_DI   PIN_B4
#define SPI_DO   PIN_C7
asmboy
PostPosted: Fri May 22, 2009 11:52 am     Reply with quote
one of many reasons to use the data sheet and forget the wiz
