sht75 crc
overmindx
sht75 crc
PostPosted: Tue May 19, 2009 8:35 pm     Reply with quote
Hello everybody, has anybody used the crc feature of sht75? How can I implement it? Please help. Thanks.
asmallri
PostPosted: Tue May 19, 2009 11:40 pm     Reply with quote
I sell the source code for the SHT75 sensor that includes CRC validation. Details are here: http://www.brushelectronics.com/index.php?page=software#SENSIRION
Regards, Andrew
PostPosted: Wed May 20, 2009 6:54 pm     Reply with quote
Andrew: And you have it at a very fair price too, IMHO....
If I need one - you have my business....
I am looking at the boot loaders however as I probably need this technology.
Steve H.
bungee-
PostPosted: Thu May 21, 2009 10:08 am     Reply with quote
According to application note that would not be so hard, there is written how to implement it. On the 7th page is pascal source code for CRC lookup.
PostPosted: Thu May 21, 2009 10:23 am     Reply with quote
Use Google to search for:
sht75 crc int char
You find sample code here:
http://www.microchip.com/forums/tm.aspx?m=368365
See the attachment to Brem's post.
This is C18 code, so an 'int' is a 16-bit signed integer, but in CCS, an 'int'
is an 8-bit unsigned integer.
wangine
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Sun Sep 06, 2015 6:47 pm     Reply with quote
sht75 crc int char
I try to convert for CCS but without success. I need to read humidity from 6 SHT75 sensors in one room. I use Hansolo driver right now, https://www.ccsinfo.com/forum/viewtopic.php?t=28564
The driver is working below 2 meters cable, thats good but the humidity look strange, a little bit high. That compare with other industrial humidity device, also i try to simulate in Proteus and look the same, humidity more high than real.
SHT75.h
// SHT75 Temp & Humid sensor
#ifndef _SHT75_H_
#define _SHT75_H_
void SHT75_Init( void);
void SHT75_TimerTick( void);
//   int16 SOt;         // Raw value temp
//   int16 SOrh;         // Raw value rh
#define sht_data_pin   PIN_B0
#define sht_clk_pin    PIN_B1
//typedef.h
 typedef union
    unsigned int16 _word;
    struct
       unsigned int8 byte0;
       unsigned int8 byte1;
 } WORD_16;
struct _SHT75
   unsigned newdata:1;
   unsigned continuous:1;
   unsigned int8 error;
   unsigned int8 state;
   unsigned int8 timeout;
   WORD_16 SOt;         // Raw value temp
   WORD_16 SOrh;         // Raw value rh
   int16 T;            // temp in 0.01 degree C
   int16 RH;            // rel humidity in 0.01%
   int16 DP;            // dew point (not yet)
   unsigned int8 crc;
 struct _SHT75 SHT75;
//extern struct _SHT75 SHT75;
#define SHT75_STATE_IDLE             0
#define SHT75_STATE_MEASURE_TEMP      1
#define SHT75_STATE_WAITING_TEMP       2
#define SHT75_STATE_COOLDOWN_TEMP       3
#define SHT75_STATE_MEASURE_RH         4
#define SHT75_STATE_WAITING_RH          5
#define SHT75_STATE_COOLDOWN_RH       6
#define SHT75_STATE_ERROR             9
#define SHT75_ERROR_NOACK            1
#define SHT75_ERROR_BADCRC            2
#define SHT75_ERROR_TIMEOUT            3
and SHT75.c
// SHT75 Commands
#define SHT75_CMD_MEASURE_TEMP   0b00000011
#define SHT75_CMD_MEASURE_HUMID  0b00000101
#define SHT75_CMD_READ_STATUS    0b00000111
#define SHT75_CMD_WRITE_STATUS   0b00000110
#define SHT75_CMD_SOFT_RESET     0b00011110
// Howmany times per second will SHT75_TimerTick() be called? Used to compute 1sec delay in between readings
#define SHT75_DELAY_1SEC                (delay_ms(1000))
// SDA & SCK, with very crude delays
#define SDA_LO    {output_low(sht_data_pin); delay_us(1);}
#define SDA_HI    {output_float(sht_data_pin); delay_us(2);}
#define SDA       input_state(sht_data_pin)
#define SCK_HI    {output_high(sht_clk_pin); delay_us(2);}
#define SCK_LO    {output_low(sht_clk_pin); delay_us(1);}
// Private function protos
void SHT75_StartTransmission( void);
void SHT75_EndTransmission( void);
void SHT75_WriteByte( unsigned char c);
void SHT75_WriteAck( void);
unsigned char SHT75_ReadByte( void);
unsigned char SHT75_ReadAck( void);      //
unsigned char SHT75_CheckCRC( unsigned char b1, unsigned char b2, unsigned char b3);
// Init...
//sht_init();
   delay_us(1);
   delay_us(1);
   SHT75.newdata    = 0;         // No new data available yet..
   SHT75.continuous = 1;         // Start continuous reading
   SHT75.state   = SHT75_STATE_IDLE;
   SHT75.timeout = SHT75_DELAY_1SEC;
   SHT75.T = 0;
   SHT75.RH = 0;
   delay_ms(1);               // Just wait a while...
   SHT75_StartTransmission();      // And a soft reset plz..
   SHT75_WriteByte( SHT75_CMD_SOFT_RESET);
   SHT75_ReadAck();
   SHT75_EndTransmission();
// Should be call every somany msecs
   switch( SHT75.state)
   case SHT75_STATE_IDLE:
      if( SHT75.continuous)
         SHT75.state = SHT75_STATE_MEASURE_TEMP;
      SHT75.error=0;
   case SHT75_STATE_MEASURE_TEMP:
      SHT75_WriteByte( SHT75_CMD_MEASURE_TEMP);
      if( !SHT75_ReadAck())
         SHT75.error   = SHT75_ERROR_NOACK;
         SHT75.state   = SHT75_STATE_ERROR;
      SHT75.state   = SHT75_STATE_WAITING_TEMP;
   case SHT75_STATE_WAITING_TEMP:
      if( SDA == 0)      // SHT75 will pull SDA low when done measuring
         SHT75.SOt.byte1 = SHT75_ReadByte();
         SHT75_WriteAck();
         SHT75.SOt.byte0 = SHT75_ReadByte();
         SHT75_WriteAck();
         SHT75.crc       = SHT75_ReadByte();
         if( !SHT75_CheckCRC(  SHT75_CMD_MEASURE_TEMP, SHT75.SOt.byte1, SHT75.SOt.byte0))
            SHT75.error   = SHT75_ERROR_BADCRC;
         // Compute T, 0.01 deg's
         // For 5V supply, 14 bit accuracy: T = -40.00 + 0.01*SOt
         SHT75.T = -4000 + SHT75.SOt._word;
         SHT75.state = SHT75_STATE_COOLDOWN_TEMP;
         if( --SHT75.timeout >0)
         SHT75.error   = SHT75_ERROR_TIMEOUT;
   case SHT75_STATE_COOLDOWN_TEMP:
      SHT75.state = SHT75_STATE_MEASURE_RH;
   case SHT75_STATE_MEASURE_RH:
      SHT75_WriteByte( SHT75_CMD_MEASURE_HUMID);
      SHT75.state   = SHT75_STATE_WAITING_RH;
   case SHT75_STATE_WAITING_RH:
         SHT75.SOrh.byte1 = SHT75_ReadByte();
         SHT75_WriteAck();
         SHT75.SOrh.byte0 = SHT75_ReadByte();
         SHT75_WriteAck();
         if( !SHT75_CheckCRC(  SHT75_CMD_MEASURE_HUMID, SHT75.SOrh.byte1, SHT75.SOrh.byte0))
            // Compute RH, 0.01%'s
            // For 12 bit acc: RH = -4 + 0.0405 * SOrh  -  0.0000028*(SOrh*SOrh)
            long SO = SHT75.SOrh._word;
            long SO2 = SO*SO;         // squared
            SO2 *= -28;               // need extra divide by 10
            SO2 /= 100000;            // should divide with 6 zero's, 1 more for the use of 28 iso 2.8, 2 less to make result in 0.01% units
                                 // makes 5 zero's
            SO *= 405;               // multiply by 4.05
            SO /= 100;               //
            SO = -400 + SO + SO2;      // Final addition.
            SHT75.RH = SO;
         SHT75.state = SHT75_STATE_COOLDOWN_RH;
      else //
   case SHT75_STATE_COOLDOWN_RH:
      SHT75.newdata = 1;            // Make new data available
      SHT75.state = SHT75_STATE_IDLE; // Back to idle
   case SHT75_STATE_ERROR:
//      if( SHT75.error == SHT75_ERROR_BADCRC)
//u,.         Led_Set(1);
   default:
   // Transmission start sequence
   SCK_HI;
   SDA_LO;
   SCK_LO;
   SCK_HI;
   SDA_HI;
   SCK_LO;
   // Idle state
   SDA_HI;
   SCK_LO;
   char bits=8;
   while( bits--)
      if( c & 0b10000000)
         SDA_HI
         SDA_LO;
      SCK_HI;
      SCK_LO;
      c <<=1;
   SDA_HI;
   SDA_LO;
   SCK_HI;
   SCK_LO;
   SDA_HI;
   unsigned char bits=8;
   unsigned char rsl=0;
   while( bits--)
      rsl <<=1;
      SCK_HI;
      if( SDA)
         rsl |= 1;
      SCK_LO;
   return rsl;
   SCK_HI;
   rsl = SDA; // SDA low means ack received
   SCK_LO;
   return (rsl==0);
rom unsigned char CRC_Table[256] =
      0,  49,  98,  83, 196, 245, 166, 151, 185, 136, 219, 234, 125,  76,  31,  46,
     67, 114,  33,  16, 135, 182, 229, 212, 250, 203, 152, 169,  62,  15,  92, 109,
    134, 183, 228, 213,  66, 115,  32,  17,  63,  14,  93, 108, 251, 202, 153, 168,
    197, 244, 167, 150,   1,  48,  99,  82, 124,  77,  30,  47, 184, 137, 218, 235,
     61,  12,  95, 110, 249, 200, 155, 170, 132, 181, 230, 215,  64, 113,  34,  19,
    126,  79,  28,  45, 186, 139, 216, 233, 199, 246, 165, 148,   3,  50,  97,  80,
    187, 138, 217, 232, 127,  78,  29,  44,   2,  51,  96,  81, 198, 247, 164, 149,
    248, 201, 154, 171,  60,  13,  94, 111,  65, 112,  35,  18, 133, 180, 231, 214,
    122,  75,  24,  41, 190, 143, 220, 237, 195, 242, 161, 144,   7,  54, 101,  84,
     57,   8,  91, 106, 253, 204, 159, 174, 128, 177, 226, 211,  68, 117,  38,  23,
    252, 205, 158, 175,  56,   9,  90, 107,  69, 116,  39,  22, 129, 176, 227, 210,
    191, 142, 221, 236, 123,  74,  25,  40,   6,  55, 100,  85, 194, 243, 160, 145,
     71, 118,  37,  20, 131, 178, 225, 208, 254, 207, 156, 173,  58,  11,  88, 105,
      4,  53, 102,  87, 192, 241, 162, 147, 189, 140, 223, 238, 121,  72,  27,  42,
    193, 240, 163, 146,   5,  52, 103,  86, 120,  73,  26,  43, 188, 141, 222, 239,
    130, 179, 224, 209,  70, 119,  36,  21,  59,  10,  89, 104, 255, 206, 157, 172
// Compute CRC of command byte and 2 rcvd bytes, and checks it against CRC stored in global struct
   unsigned char crc = 0;
   unsigned char tmp = 0;
   unsigned char bits= 8;
   crc = CRC_Table[ crc ^ b1];
   crc = CRC_Table[ crc ^ b2];
   crc = CRC_Table[ crc ^ b3];
   while( bits--)
      tmp >>=1;
      if( crc & 0b10000000)
         tmp |= 0b10000000;
      crc <<=1;
   return (tmp==SHT75.crc);
The driver is stuck somehow, just initialise sensor, send some data and sto , no communication after 1 second.
I think the problem is here, but i don't know how to solve.
here original for C18
#define SHT75_DELAY_1SEC                (1000/TIMER_TICK)
#define SDA_LO    {SHT75_SDA_Tris(0); Delay10TCYx( 1);}
#define SDA_HI    {SHT75_SDA_Tris(1); Delay10TCYx( 1);}
#define SDA       SHT75_SDA_Get()
#define SCK_HI    {SHT75_SCK_Set(1); Delay10TCYx( 1);}
#define SCK_LO    {SHT75_SCK_Set(0); Delay10TCYx( 1);}
The original driver in PCM Programmer link.
Thanks and sorry for my english.
PostPosted: Mon Sep 07, 2015 5:29 am     Reply with quote
What humidity value(s) did you read ? How do you know it's too high ?
You must be comparing it to some other unit, that you're using as a
standard.
wangine
PostPosted: Mon Sep 07, 2015 5:53 am     Reply with quote
What do you want us to do ? You posted some C18 code, but your
complaint is about the Han Solo code in the Code Library.
If you have a complaint about the Han Solo code, then post the results
that you expected to get, and also post what you are actually getting.
Explain how you know the humidity from the Han Solo code is incorrect.
On HanSolo code humidity is correct only at 27 *C, i compare with Fluke 971 meter and for temperature compare i use Fluke 289 multimeter with temperature probe. Also i have in the same isolated tobacco room other 4 analog humidity sensors, with some pic18xx controllers. Temperature looks good on 34*C, between 20 and 90*C the error is around 4.8*C, my compare temperature probe have error 0,012%
I didn't post a C18 code, i modify entire code trying to get CRC check. On end of post i put the part that i believe is wrong. To understand the entire Hansolo code, need time, the same time can be used to write a new one. I say just i used a Hansolo code and after some tests i notice humidity is more high than meter and others sensors show in same room, same position.
Now my question is if some one can help me to understand where is the problem on the code i posted below because i really want to include a CRC check. The code is compiled without errors in CCS, but somewhere the code stuck in some loop, the temperature and humidity variables return 0 all time.
PostPosted: Mon Sep 07, 2015 8:05 am     Reply with quote
You try breaking up your program into two sections
1) reading the sensor
2) computing the temp/humid from the readings.
If you put known 'dummy' values instead of reading the sensors you'll get to know if the 'math' for computing the temperature and humidity are correct. I'm sure the SHT75 datasheet will have known values say for 0*C, 100*C or similar. By doing this you can confirm the 'math' is right or wrong.
Once this is working 100%, then get real data from the sensors at a known temperature and humidity,compared to your Fluke test equipment. If there is an error, it's with the sensors or communications NOT the 'math' sections.
Right now you could have a small problem in BOTH sections, reading and computing making it impossible to 'see' where the problems are.
Jay
wangine
PostPosted: Mon Sep 07, 2015 10:45 am     Reply with quote
Yup, are perfectly right , when i begin to made some driver, i made separate function for test each part. After all has success, i put all parts together, but in this case the code is already done, and need to understand piece by piece to start to divide sections. I put answer here not because i want to get code to work free, just i think some are more smart or already studied or know that. I am 99% sure the mistake is in math part, but is weird because the math look exactly like in datasheet.
On second code (C18), is difficult, i understand just some section of code, far away CRC section for me. Right now i work on SHT25 driver, i buy 5 sensors on 4 diferent countries, include chinese. I finish some different hardware with diferent pic's and ... i still work. Driver look like SHT75 but is not the same, i need more study. Thanks for all answers.
PostPosted: Mon Sep 07, 2015 1:28 pm     Reply with quote
What's the oscillator frequency for your PIC ?
The translated code below would be accurate if PIC is running at 40 MHz.
But where did the sht75.c and sht75.h files originally come from ?
What was the PIC oscillator frequency on the original project ?
wangine
PostPosted: Mon Sep 07, 2015 2:11 pm     Reply with quote
SHT75.h
#ifndef _SHT75_H_
#define _SHT75_H_
struct _SHT75
   unsigned newdata:1;
   unsigned char error;
   unsigned char state;
   unsigned char timeout;
   WORD SOt;         // Raw value temp
   WORD SOrh;         // Raw value rh
   int T;            // temp in 0.01 degree C
   int RH;            // rel humidity in 0.01%
   int DP;            // dew point (not yet)
   unsigned char crc;
and sht75.c
// SHT75.c
#include <p18cxxx.h>
#include <typedefs.h>
#include "io_cfg.h"
#include "SHT75.h"
#include <timedelays.h>
// SHT75 Commands
// Init...
//#if (CAN_SOURCEADDRESS == CAN_SA_HUMIDSENSOR3)
   LATCbits.LATC4 = 1;             // function as Pull up, error in PCB
//#endif
   SHT75_SDA_Set(0);            //
   SHT75_SDA_Tris(1);            // SDA High imp
   SHT75_SCK_Tris(0);            //
   SHT75_SCK_Set(0);            // CLK Low
   SHT75.T = 0;
   SHT75.RH = 0;
   DelaymSec(1);               // Just wait a while...
   SHT75_ReadAck();
      SHT75.error=0;
         SHT75_WriteAck();
         SHT75_WriteAck();
         SHT75_WriteAck();
         SHT75_WriteAck();
                                 // makes 5 zero's
            SO /= 100;               //
            SHT75.RH = SO;
      else //
//u,.         Led_Set(1);
   default:
   SCK_HI;
   SDA_LO;
   SCK_LO;
   SCK_HI;
   SDA_HI;
   SCK_LO;
   // Idle state
   SDA_HI;
   SCK_LO;
   char bits=8;
   while( bits--)
      if( c & 0b10000000)
         SDA_HI
         SDA_LO;
      SCK_HI;
      SCK_LO;
      c <<=1;
   SDA_HI;
   SDA_LO;
   SCK_HI;
   SCK_LO;
   SDA_HI;
   while( bits--)
      rsl <<=1;
      SCK_HI;
      if( SDA)
         rsl |= 1;
      SCK_LO;
   return rsl;
   SCK_HI;
   SCK_LO;
   return (rsl==0);
   while( bits--)
      tmp >>=1;
         tmp |= 0b10000000;
      crc <<=1;
Has take from your sugestion on brem's post on C18 forum , typedef.h missing but i made one include to don't modify the original code just int8/16/32 variables , is different on C18
this deff///
//typedef.h
 typedef union
    struct
 } WORD_16;
and i try to don't modify any function , right now i found where code stuck.
. The loop never go out from here because case function don't have a valid state, if i pass CRC loop , the temperature return only 7520 , and stuck like that .Im so lost right now
wangine
PostPosted: Sat Sep 12, 2015 8:55 pm     Reply with quote
standard.
I give up with CRC check, i made my own driver for SHT25 , is more faster than SHT75. Anyway the last test i made with SHT75 and Hansolo code was :// I put in a high pressure vessel (6 bar) water to a boil in which 99.99999% humidity is normal and the temperature 117 ° C, and sensor looks 117.82 temperature and humidity 120.29 RH, and that is impossible, right ? I will try in the next few days to calibrate the code after some different tests with different sensors. I have 6 sensors and 3 different hardware, pic18f4550, pic18f4520 and dspic33FJ128MC804.
