How to send more than 6 bytes with HID ?
philippe320
PostPosted: Tue May 19, 2009 11:00 am     Reply with quote
I'm using that descriptors in my 18F2550
   const char USB_CLASS_SPECIFIC_DESC[] = {
      6, 0, 255,      // Usage Page = Vendor Defined
      9, 1,           // Usage = IO device
      0xa1, 1,        // Collection = Application
      0x19, 1,        // Usage minimum
      0x29, 8,        // Usage maximum
      0x15, 0x80,     // Logical minimum (-128)
      0x25, 0x7F,     // Logical maximum (127)
      0x75, 8,        // Report size = 8 (bits)
      0x95,    [color=red]6[/color],     // Report count = 16 bits (2 bytes)
      0x81, 2,        // Input (Data, Var, Abs)
      0x95,    [color=red]2[/color],     // Report count = 16 bits (2 bytes)
      0x91, 2,        // Output (Data, Var, Abs)
      0xc0            // End Collection
I'd like to send more than 6 bytes, but when changing the first red data to 16 for example, the transmission fails
I tested that USB_USE_FULL_SPEED is TRUE
and USB_MAX_EP0_PACKET_LENGTH is 64
and USB_EP1_TX_SIZE is 64
So, I should transmit up to 64 bytes at a time ...
Why not
Thanks in advance
Regards
Philippe
Most of usb_desc_hid.c deleted.
Reason: Forum rule #10
10. Don't post the CCS example code or drivers.
-- Forum moderator
