CAN with PIC24
raroca
CAN with PIC24
PostPosted: Wed Nov 28, 2007 1:03 pm     Reply with quote
Have anyone already used CCS CAN libraries with PIC24?
The PIC Wizard creates a code using:
#include <can-18xxx8.c >
The function
can_init()
does not give error,
but the
can_putd(...)
gives the following error at compilation time:
Function used but not defined: ... can_putd SCR=3120
if i change the parameters, the SCR value changes, but it never works!
any idea/hints?
thanks
Rafael
john7188
PostPosted: Fri Sep 26, 2008 11:24 am     Reply with quote
I'd like to know about CAN w/ the PIC24 as well....
I'm about to work on the CAN portion of a project and don't want to get started without being sure the CCS CAN libraries will work correctly...
John5788
PostPosted: Mon May 18, 2009 5:22 pm     Reply with quote
i am curious as well
PostPosted: Mon May 18, 2009 5:42 pm     Reply with quote
The original poster is attempting to use 18F files for the PIC24 PICs.
Use the driver files for the PIC24 series. Here's the location:
c:\program files\picc\drivers\can-pic24.c
c:\program files\picc\drivers\can-pic24.h
These files come with the compiler (vs. 4.092).
