How to make function argument optional?
Futterama
PostPosted: Fri Sep 01, 2006 3:43 am     Reply with quote
Hello forum,
How do I make a function's argument optional?
And how do I check if an argument was passed when the function was called?
Thanks.
Futterama
PostPosted: Fri Sep 01, 2006 4:10 am     Reply with quote
You can't.
This is one of the features added in V4. You can do various forms of 'bodge round' this, with the normal technique being to pass a pointer to an array arguments.
Futterama
PostPosted: Fri Sep 01, 2006 4:20 am     Reply with quote
Thanks for the reply.
Oli
PostPosted: Mon May 18, 2009 6:21 am     Reply with quote
Just an update to this topic - does anybody know how to make an argument optional? (and set a default value if it's not passed?)
Many thanks
PostPosted: Mon May 18, 2009 7:48 am     Reply with quote
With V4, you just use an overload.
So (for example):
void function(int8 val) {
   //Function code here
void function(void) {
   function(10);
If you pass a value, the first function gets called, while if you don't, the second gets called, and this then calls the first, with the value defaulting to '10'.
Overloading, is one part of V4, that has been working surprisingly well.
Oli
PostPosted: Mon May 18, 2009 9:25 am     Reply with quote
Thanks again Ttelmah
