check a frequency in pic's mcu
linda p.r
PostPosted: Sun May 17, 2009 1:02 am     Reply with quote
Hi
I am using pic's for many time and now we have to do a project in university, and I found myself in a problem with counting pulses.
What is the best way in ccs c to check if an input is 10 hertz ??
AND what is the best way to count pulses ?
If anyone has a code for the first one it will be good .
Thanks a lot.
PostPosted: Sun May 17, 2009 2:53 am     Reply with quote
For the frequency measurement, you get the fastest response by measuring the period , counting timer ticks between two pulses. There are different solutions depending on the PIC chip and your applications's overall structure.
Pulse counting can be done by a hardware or a software counter, the latter typically interrupt based (Ext or pin change interrupt).
I think, there are programming examples for both tasks shipped with the compiler.
asmboy
using internal timer1 with gate mode
PostPosted: Sun May 17, 2009 9:29 am     Reply with quote
i've done counting of some pretty short pulses with fast polling and the following code on an F887 - 8mhz int clock and dealing with from 10hz to 1000hz frequencies using:
// NOTE: timer one gate pin and C0 are tied together externally
// partial  init code
 unsigned int8 rotoken=0; // initial state
 unsigned int16 rotcount;
 set_tris_b( 0b00100000 );     // all output except #5 NOT T1G  gate
//         following  must be done for TIMER 1 gate to work
     setup_comparator(NC_NC|CP2_T1_GATE);  // no comparators
//         with an 8 mhz internal clock - each tick is 500ns duration
     setup_timer_1( T1_INTERNAL|T1_GATE_INVERTED );  // set for rollovers
     set_timer1(0); //  so we get a TMR1IF rollover for later
//    measure  duration of a HI pulse on timer 1 gate
//    pin C0 is used to alert hi level polling of zero between
//    measured pulse width  - duration of pulse positive
//    is counted in "ticks" of
//    TOKEN 0
void dunno ( void) {  // no knowlege of where we are hi or low
    if (!input(PIN_C0)) {  // wait for LOW state of clock and advance
          set_timer1(0);   //  reset timer
          rotoken=1;       // expecting to see a RISE next
//   TOKEN 1
void hiyet ( void) {  // wait for flag to go HI meaning we r counting
    if (input(PIN_C0))  rotoken=2; // expecting to see a RISE next
//   TOKEN 2
void harvest ( void) {  // wait for flag to go HI meaning we are counting
    if (0==input(PIN_C0)){
       //  detect overlong count first
       if (TMR1IF) { rotcount =0; TMR1IF=0;} // overlong , low speed detected
       else {
            rotcount += get_timer1();
            rotcount /= 2;     // stack up the count, roll the average ahead
        set_timer1(0);     //  reset timer for next
       //  RPM 6 pole motor , counting TACH pulse [+ time] = (2635200/rotcount);
//  rotmon is POLLED frequently enough from MAIN() to grab the counts
void rotmon(void){
            switch (rotoken) {
             // case 0 - dont know if we are low or high
             case 0 :   dunno();       break;     // state unsure get in sync
             case 1 :   hiyet();       break;     // did count start yet ?
             case 2 :   harvest();     break;     // get reset value
             default :
