i2c in PIC16F84A
horde_fuego
i2c in PIC16F84A
PostPosted: Fri May 15, 2009 4:14 am     Reply with quote
Is this possible with PIC16F84A alone? I need more i/o pins but unfortunately we don't have any PIC16F877A or any other PICs. Will the command from CCS C like i2c_start() or i2c_read work even if it doesn't have any dedicated SCL and SDA in it?
Any suggestions or clarifications or tips will be highly appreciated. Thanks in advance!! Very Happy Very Happy Smile
PostPosted: Fri May 15, 2009 8:31 am     Reply with quote
Yes.
CCS, implements a software I2C master, if you just use any pins on the chip, that don't have hardware I2C abilities.
All the standard library functions work quite well.
Half of the library examples, for I2C, default to chips without the hardware present. Smile
rnielsen
PostPosted: Fri May 15, 2009 9:35 am     Reply with quote
You need to understand that software I2C works in Master mode. If you're wanting to have a PIC run as a Slave you had better select one that has the hardware built in.
You can assign SCL & SDA to almost any pin you want to use. There are a few exceptions, like a pin that's Input only or something that's dedicated to a certain function. Otherwise, the compiler takes care of everything for you. Just put the correct pin assignments in your #use i2c() statement and you're ready to fly.
Ronald
horde_fuego
PostPosted: Sat May 16, 2009 5:03 am     Reply with quote
thank you very much!!!i'll try it now! Very Happy Smile
