Tagge
RTC-4543SA |
Posted: Wed May 13, 2009 10:56 am |
Hi, has anyone made a driver for this RTC?
Im working on one but do have some trouble, as usually..
Made this far, but aint getting out the right stuff.
Code: | #ifndef RTC_SCLK
#define RTC_SCLK PIN_E6
#define RTC_IO PIN_E7
#define RTC_WR PIN_C1
#define RTC_CE PIN_C0
#endif
void write_rtc(BYTE data, BYTE length)
int8 i=0;
printf("test write_rtc: %u; length: %u\r\n",data, length); //ok!!
for(i=0;i<=length;++i) {
output_bit(RTC_IO, shift_right(&data,1,0) );
output_high(RTC_SCLK);
delay_us(2);
output_low(RTC_SCLK);
delay_us(2);
BYTE read_rtc(BYTE length)
BYTE i,data;
shift_right(&data,1,input(RTC_IO));
delay_us(2);
delay_us(2);
printf("test read rtc data: %u; \r\n",data); //Nok!!
return(data);
int get_bcd(BYTE data)
int nibh;
int nibl;
nibh=data/10;
nibl=data-(nibh*10);
return((nibh<<4)|nibl);
int rm_bcd(BYTE data)
int i;
i=data;
data=(i>>4)*10;
data=data+(i<<4>>4);
return data;
void rtc_set_datetime(BYTE min, BYTE hr, BYTE dow, BYTE day, BYTE mth, BYTE year)
output_high(RTC_CE); //enable rtc
output_high(RTC_WR); //write enable
delay_us(10);
write_rtc(get_bcd(0),7); //sekunder 0
write_rtc(get_bcd(min),7); //min 0-59
write_rtc(get_bcd(hr),7); //Timmar 0-59
write_rtc(get_bcd(dow),3); //day of week 1-7
write_rtc(get_bcd(day),7); //day 1-31
write_rtc(get_bcd(mth),7); //mounth 1-12
write_rtc(get_bcd(year),7); //year 0-99
output_low(RTC_CE); //disable rtc
output_low(RTC_WR); //disable write
void rtc_get_date(BYTE& day, BYTE& mth, BYTE& year, BYTE& dow)
int8 slask =0;
output_low(RTC_WR); //read enable
delay_us(10);
slask =(read_rtc(7));slask =(read_rtc(7));slask =(read_rtc(7));
dow = rm_bcd(read_rtc(3));
day = rm_bcd(read_rtc(7));
mth = rm_bcd(read_rtc(7));
year = rm_bcd(read_rtc(7));
printf("test read_rtc: %u\r\n",year); //nok!!
void rtc_get_time(BYTE& hr, BYTE& min, BYTE& sec)
int8 slask=0;
delay_us(10);
sec = rm_bcd(read_rtc(7));
min = rm_bcd(read_rtc(7));
hr = rm_bcd(read_rtc(7));
delay_us(10);
slask=(read_rtc(3));slask=(read_rtc(7));slask=(read_rtc(7));slask=(read_rtc(7));
////////////////////////////////////////////7
void set_time(){
BYTE my_in[3]="",answer=0, my_sek=0, my_min=0, my_hour=0, my_dow=0,my_day=0,my_mth=0,my_year=0;
fprintf(USER,"min:\r\n");
fgets(my_in,USER);
my_min=atoi(my_in);
fprintf(USER,"hour:\r\n");
fgets(my_in,USER);
my_hour=atoi(my_in);
fprintf(USER,"dow:\r\n");
fgets(my_in,USER);
my_dow=atoi(my_in);
fprintf(USER,"day:\r\n");
fgets(my_in,USER);
my_day=atoi(my_in);
fprintf(USER,"month:\r\n");
fgets(my_in,USER);
my_mth=atoi(my_in);
fprintf(USER,"year:\r\n");
fgets(my_in,USER);
my_year=atoi(my_in);
fprintf(USER,"Written:%u:%u:%u:%u:%u:%u\r\n Right Y,N?\r\n",my_min,my_hour,my_dow,my_day,my_mth,my_year);
do{
answer=fgetc(USER);
}while(answer!='Y' && answer!='N');
if(answer=='Y')
rtc_set_datetime(my_min, my_hour, my_dow, my_day, my_mth, my_year);
else fprintf(USER,"Not saved\r\n");
//testa
rtc_get_time(my_hour,my_min, my_sek);
fprintf(USER,"Time %u:%u:%u\r\n",my_hour,my_min,my_sek);
rtc_get_date(my_day,my_mth,my_year,my_dow);
fprintf(USER,"Date %u:%u:%u; %u\r\n",my_day,my_mth,my_year,my_dow);
//eof |
print from the program in hyperterminal:
test write_rtc: 0; length: 7
test write_rtc: 53; length: 7
test write_rtc: 24; length: 7
test write_rtc: 4; length: 3
test write_rtc: 9; length: 7
test write_rtc: 5; length: 7
test read rtc data: 0;
test read rtc data: 106;
test read rtc data: 48;
test read rtc data: 3;
Time 30:70:0
test read rtc data: 131;
test read rtc data: 18;
test read rtc data: 10;
test read_rtc: 12
Date 12:10:12; 83
Any suggestions gladly taken
Thanks/Tagge |
Tagge
Posted: Wed May 13, 2009 2:11 pm |
I think I find one issue when reading the data of the RTC, when writing to and reading from it I have to use 8-bits! altough its only 7 bits of data. It could maybe be done by just let the clock make an extra pulse after the data?
Like Code: | void write_rtc(BYTE data, BYTE length)
int8 i=0;
delay_us(2);
delay_us(2);
delay_us(2);
What do you think? |
Posted: Wed May 13, 2009 2:42 pm |
According to the Application manual, it wants 52 clock pulses for a write
cycle. On page 7, it says:
Quote: | Note that during a write operation, 52 bits of data must be input. |
http://www.epsontoyocom.co.jp/english/product/RTC/set02/rtc4543sa_sb/index.html
You are only doing 45 bits.
This RTC chip does not have a byte-oriented interface. Modern RTC
chips have standard SPI or i2c interfaces. Why are you using this
strange chip ? |
Tagge
Posted: Wed May 13, 2009 3:18 pm |
I agree, but it wasn't up to me to use this chip
I hate it! must be from the time of the roman empire..
And your right, about the 52 bits, but I assume that its enough to just let the clock make a extra cycle? because the eight bit isn't used, only clocked in..
Or maybe it should consist of something, a zero maybe.
its the same thing when reading, I'm trying to throw away the bits that are not of interest.
But do you think the driver would work? I haven't tested with the 52 bits yet.
Is the bcd function right though?
thanks/Tagge |
Posted: Wed May 13, 2009 3:48 pm |
The application note (which you can download and read) says:
Quote: |
Correct write access isn't completed when CE terminal [is] turned into
low [level] on a state of less than 52 bits. |
You can't make up your own spec. You have to follow the manufacturer's
documentation.
Quote: | Is the bcd function right though? |
The get_bcd() and rm_bcd() functions were copied from the CCS driver
file, ds1302.c, so presumably they should work. |
Tagge
Posted: Thu May 14, 2009 3:17 am |
Hi again, I got it almost working
Its writing allright until the "month", there something goes wrong..
The 8-bit of the month must be a '0' acording to data sheet, it should be 0 anyway as months only are between 1-12..
Strange thing is that months also work, but not if entered between 4-7!!
year doesnt work at all, almost allways 0,1 or +100..
I suspect it could have something to do with the dow byte that is only 4 bits long?? Im sending just a 0 to it, but Im nor sure how its accepted by the write_rtc() function?
Time works fine both write and read.
Code: | void rtc_set_datetime(BYTE min, BYTE hr, BYTE dow, BYTE day, BYTE mth, BYTE year)
delay_us(10);
write_rtc(get_bcd(0),8); //sekunder 0
write_rtc(get_bcd(min),8); //min 0-59
write_rtc(get_bcd(hr),8); //Timmar 0-59
write_rtc(0,4);//get_bcd(dow),4); //day of week 1-7, dont needed
write_rtc(get_bcd(day),8); //day 1-31 OK
write_rtc(get_bcd(mth),8); //mounth 1-12 NOK!
write_rtc(get_bcd(year),8); //year 0-99
//=52 bits
testing:
Code: | void rtc_get_date(BYTE& day, BYTE& mth, BYTE& year) {
int8 slask =0;
delay_us(10);
//THROW AWAY FIRST 28 BITS
slask =read_rtc(8);slask =read_rtc(8);slask =read_rtc(8);slask = read_rtc(4);
day = rm_bcd(read_rtc(8));//OK
mth = rm_bcd(read_rtc(8));//NOK
year = rm_bcd(read_rtc(8));
Posted: Thu May 14, 2009 12:13 pm |
Try masking it down, so the bcd function only operates on the valid bits.
Example:
Quote: | mth = rm_bcd(read_rtc(8) & 0x1F); |
If that doesn't work, then post a list of the values that you are writing to
each register, and also post what you read back. |
Tagge
Posted: Thu May 14, 2009 12:28 pm |
Hi, thanks,
Tested your suggestion, but no change.
Im trying to write for example:
Written:10:20:4:14:5:9
Right Y,N?
Time 20:10:0 //this is ok
Date 2000:0:14 //only day ok
I found a sort of driver but its not in CCS, that seems to take care of the 4 bit "byte", that is maybe the trouble, it looks like this, some changes made by me, but still a non working code.. Im quite tired, so I havent figured it out all, yet at least..
Code: | void write_rtc_buffer(BYTE *my_buffer, int8 len){
int8 rem = 0;
BYTE accu, shift;
delay_us(10);
for (rem = len; rem > 0; ) {
for (shift = 0, accu = *my_buffer++;(rem > 0) && (shift < 8);
rem--, shift++) {
output_bit(RTC_IO,(accu & 0x01)); /* LSB first */
delay_us(10);
delay_us(10);
accu >>= 1;
output_low(RTC_CE); //enable rtc
output_low(RTC_WR); //write enable
//And the writing function:
void rtc_set_all(BYTE min, BYTE hr,BYTE dow, BYTE day, BYTE mth, BYTE year){
BYTE my_buffer[7];
BYTE tmp = 0, sec=0, i=0;
my_buffer[0]=get_bcd(sec);
my_buffer[1]=get_bcd(min);
my_buffer[2]=get_bcd(hr);
my_buffer[3]=get_bcd(dow);
tmp=get_bcd(day);
my_buffer[3]=(tmp&0x0f)<<4;
my_buffer[4]=(tmp&0xf0)>>4;
tmp=get_bcd(mth);
my_buffer[4]=(tmp&0x0f)<<4;
my_buffer[5]=(tmp&0xf0)>>4;
tmp=get_bcd(year%100);
my_buffer[5]=(tmp&0x0f)<<4;
my_buffer[6]=(tmp&0xf0)>>4;
write_rtc_buffer(my_buffer,52);
Posted: Thu May 14, 2009 12:34 pm |
Quote: | Written:10:20:4:14:5:9
Right Y,N?
Date 2000:0:14 //only day ok |
You are entering the data in a different order than it's displayed,
so it's difficult for me to correlate the input and output values.
Please post a 1:1 list showing the entry value and the output. |
Tagge
Posted: Thu May 14, 2009 1:03 pm |
Ok, entering as:
Code: | rtc_set_datetime(my_min, my_hour, my_day, my_mth, my_year); |
And the values are:
40:20:4:14:5:9
void rtc_set_datetime(BYTE min, BYTE hr, BYTE day, BYTE mth, BYTE year)
delay_us(10);
write_rtc(0,8); //sek 0
write_rtc(get_bcd(min),8); //min 40
write_rtc(get_bcd(hr),8); //hour 20
write_rtc(0,4);//get_bcd(dow),4); //day of week 1-7 Not used! just 0
write_rtc(get_bcd(day),8); //day 14
write_rtc(get_bcd(mth),8); //month 5
write_rtc(get_bcd(year),8); //year 9
delay_ms(1);
delay_ms(1);
And the output when read in this case is:
sec = 0;
min = 40
hour =20
day = 14
month = 0
year = 0 |
Posted: Thu May 14, 2009 1:06 pm |
And the values are:
40:20:4:14:5:9 |
There are 5 parameters in your function, but 6 items in your values list.
Please identify the values. |
Tagge
Posted: Thu May 14, 2009 1:24 pm |
the dow value is only set to 0 in the function rtc_set_datetime()
write_rtc(0,4); //dow
Its asked for in the user interface, but not used further..
therefore seen as the 4 in the user string.
Thanks for your assistance, Im really confused with this one/tagge |
Posted: Thu May 14, 2009 3:45 pm |
I would get rid of the bcd conversions, and just look at the low-level data.
Strip down your program as much as possible. Send out a data stream
and see what you get back.
There are bugs in your program. For example, the read_rtc() routine
has the possiblity of using a length less than 8 (a full byte). But, you
don't initialize 'data' to 0 before you start shifting bits into it. Suppose
your length is only 4. Then 'data' could have some random value in it,
and 4-bits of the random value would be returned, along with the valid
4 bits. See the correction below.
Quote: | BYTE read_rtc(BYTE length)
BYTE i, data;
data = 0; // *** Add this line
delay_us(2);
delay_us(2);
return(data);
You may have other bugs that I haven't seen yet. That's why I say just
strip it down as small as you can and test the raw data transfer. |
Posted: Fri May 15, 2009 5:24 am |
Hi, yes, thanks, I will try it.
But under the mean time, is there any way of building an array of bits?
as
How could it look like? and how could I pass a byte in to 8-bits in that array? and after that be able to send the bits array to the write_rtc() function.. where it has to be clocked in from the seconds LSB first until the years MSb at last..
I think that could solve the problem? then I could pass all bits one by one to the chip.
/tagge |
Tagge
Posted: Fri May 15, 2009 9:04 am |
Im confused about the BCD function, if I write in dec, for ex
Written:37:16:5:15:5:9
And then read it at the rtc_set_datetime() function as hex it says:
In set_date_time:25:10:05:0f:05:09
And thats ok, but then I send the bytes to the bin2bcd function,
Code: | BYTE get_bcd(BYTE data){
int nibh;
int nibl;
nibh=data/10;
What returns is, bcd in printf as hex:
fprintf(USER,"BCD write_rtc :%x\r\n",data);
To me it seems like its changed back to dec and not to BCD? or am Im cycling.. BCD have 4 bits for 0-9, the fifth bit for tens, 6 for twenties, 7 for forthies and so on..
In BCD write_rtc :00 //ok, in 0, sec
In BCD write_rtc :37 // min its 37 in dec to? should it be 0x25 in bcd(hex)
In BCD write_rtc :16 //hour its 16 in dec to? should be 0x0f in bcd?
In BCD write_rtc :00 //ok 0, dow
In BCD write_rtc :15 //day its 15 in dec to, ok in bcd?
In BCD write_rtc :05 //month its 5 in dec to, ok in bcd?
In BCD write_rtc :09 //year its 9 in dec to, ok in bcd?
Time 16:37:0
Date 2001:1:15 |
