If user enter on the keypad:
12.50 ( 1 2 dot 5 0 )
- How to format entered number so that it's 12.50 and not 1 2 . 5 0 or something in this matter ?
- How to process/calculate 12 dot 50 * 0.50 = 6.25
- How to write calculated value to ram ?
Regards.
Posted: Thu May 14, 2009 12:58 am
See this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=36304&start=2
Except instead of atoi(), use the atof() function. It will convert
a string of ascii numbers into a floating point value. These functions
are described in the CCS manual, and on the internet (use Google).
You now have the keypad value in a 'float' variable. Multiply it by 0.50
and store the result.
You need to learn the C language. It's a pre-requisite for this forum.
