Switching from hardware spi to software spi
J Hopkins
PostPosted: Sun May 10, 2009 2:28 pm     Reply with quote
I am using a pic18f4520 to control an fm25v10 f-ram. I am using compiler v 4.016.
I initially used a hardware spi interface to control the fram, which was simple and straight forward. However, we layed out a board with some traces in the wrong places, so I now need to use a software interface so that I can select which pins are which. I tried to develop a software interface but so far I can't seem to get it to work. I am testing both interfaces with the same setup. One thing I am wonder is, is it a problem to declare a software interface on the same pins that a hardware interface would go on?
For the test I try to write/read both a single character and a string of characters from the fram. In either case with software I get back characters that are all 1's. I know that software spi is slower than hardware, so there is no way I am outrunning the fram. The minimum setup and hold times are not even close to being violated. I don't have a scope with me so I cannot look at what the pic is sending.
This is a serious problem, as we are in a rush to ship our otherwise-working product. I would really appreciate any help anyone could offer. Thanks.
Working hardware interface:
#include <18F4520.h>
#device PASS_STRINGS = IN_RAM
#device HIGH_INTS=TRUE
#include <stdio.h>
#include <string.h>
#use delay(INTERNAL=8M, clock=16M)
#fuses INTRC//, DEBUG
//Spi Modes (F-Ram only uses 0 or 3
#define SPI_MODE_0  (SPI_XMIT_L_TO_H | SPI_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_XMIT_L_TO_H | SPI_H_TO_L)
//F-RAM Commands
#define WREN 0x06
#define WRDI 0x04
#define RDSR 0x05
#define WRSR 0x01
#define READ 0x03
#define FSTRD 0x0B
#define WRITE 0x02
#define SLEEP 0xB9
#define RDID 0x9F
#define SNR 0xC3
#define NO_WR_PROTECT 0x00
struct portb_pin_map {
   unsigned short led0;
   unsigned short led1;
   unsigned short led2;
   unsigned short led3;
   unsigned short pic_mode;
   unsigned short CTS;
   unsigned short reserved;
   unsigned short bit7;
      } portb;
#locate portb = getenv("sfr:PORTB")
struct portc_pin_map {
   unsigned short b0;
   unsigned short HOLD;
   unsigned short SS;         // SPI SS   -- Place holder.
   unsigned short SCK;         // SPI SCK   -- Place holder.
   unsigned short SDI;         // SPI SDI   -- Place holder.
   unsigned short SDO;         // SPI SDO   -- Place holder.
   unsigned short TX;         // RS232 TX   -- Place holder.
   unsigned short RX;         // RS232 RX   -- Place holder.
      } portc;
#locate portc = getenv("sfr:PORTC")
#use rs232(BAUD=9600, XMIT=PIN_A1, RCV=PIN_A0, BITS=8, PARITY=N)
void leds(int a) {
   portb.led0=a&1;
   portb.led1=(a>>1)&1;
   portb.led2=(a>>2)&1;
   portb.led3=(a>>3)&1;
void tx(char *tx) {
   int a=0;
   while(tx[a])
      putc(tx[a++]);
   putc(13);
   putc(10);
void spi_wr_enable() {
   portc.SS=0;
   spi_write(WREN);
   portc.SS=1;
void setup_fram() {
   spi_wr_enable();
   //write to status register
   portc.SS=0;
   spi_write(WRSR);
   spi_write(0b01000000);
   portc.SS=1;
void fram_write(int32 adr, char data) {
   spi_wr_enable();
   //write data
   portc.SS=0;
   spi_write(WRITE);
   spi_write((adr>>16)&1);
   spi_write((adr>>8)&0xFF);
   spi_write(adr&0xFF);
   spi_write(data);
   portc.SS=1;
void fram_read(int32 adr, char *out, int16 num) {
   int16 i=0;
   //read data
   portc.SS=0;
   spi_write(READ);
   while(num--)
      out[i++]=spi_read(0);
   out[i]=NULL;
   portc.SS=1;
void main(void) {
   int i=0;
   char message[40]="This is just a simple test.";
   char result[40];
   int32 adr=0;
   setup_oscillator(OSC_16MHZ);
   disable_interrupts(global);
   set_tris_b(0xF0);
   set_tris_c(0xA0);
   portc.SS=1;
   portc.HOLD=1;
   setup_spi (SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4 );
   setup_fram();
   do {
      fram_write(adr++,message[i]);
   while(message[i++]);
   tx(message);
   adr=0;
   fram_read(adr,result,40);
   tx(result);
   tx("\r\n");
Not working software interface:
#include <stdio.h>
#include <string.h>
//F-RAM Commands
#define WREN 0x06
#define WRDI 0x04
#define RDSR 0x05
#define WRSR 0x01
#define READ 0x03
#define FSTRD 0x0B
#define WRITE 0x02
#define SLEEP 0xB9
#define RDID 0x9F
#define SNR 0xC3
   unsigned short CTS;
      } portb;
   unsigned short b0;
      } portc;
#use spi(MASTER, MSB_FIRST, DI=PIN_C4, DO=PIN_C5, CLK=PIN_C3, BITS=8, MODE=0)
void leds(int a) {
   portb.led0=a&1;
void tx(char *tx) {
   int a=0;
   while(tx[a])
      putc(tx[a++]);
   putc(13);
   putc(10);
   portc.SS=0;
   spi_xfer(WREN);
   portc.SS=1;
void setup_fram() {
   spi_wr_enable();
   portc.SS=0;
   spi_xfer(WRSR);
   spi_xfer(0b01000000);
   portc.SS=1;
   spi_wr_enable();
   //write data
   portc.SS=0;
   spi_xfer(WRITE);
   spi_xfer((adr>>16)&1);
   spi_xfer((adr>>8)&0xFF);
   spi_xfer(adr&0xFF);
   spi_xfer(data);
   portc.SS=1;
   int16 i=0;
   //read data
   portc.SS=0;
   spi_xfer(READ);
   spi_xfer(adr&0xFF);
   while(num--)
      out[i++]=spi_xfer();
   out[i]=NULL;
   portc.SS=1;
void main(void) {
   int i=0;
   char result[40];
   int32 adr=0;
   set_tris_b(0xF0);
   set_tris_c(0xA0);
   portc.SS=1;
   portc.HOLD=1;
//   setup_spi (SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4 );
   setup_fram();
   do {
   tx(message);
   adr=0;
   tx(result);
   tx("\r\n");
PostPosted: Sun May 10, 2009 2:33 pm     Reply with quote
I strongly question whether #use spi() works in vs. 4.016.
J Hopkins
I didn't know that
PostPosted: Sun May 10, 2009 2:36 pm     Reply with quote
Thanks for responding. Are you saying I need to write my own software spi interface? Has someone already written one? I'm not an assembly expert. My background is C/C++.
PostPosted: Sun May 10, 2009 2:49 pm     Reply with quote
Don't write it in assembly. Write it in C. Look at some of the CCS
example files for the 25-series eeproms:
c:\program files\picc\drivers\25640.c
