Help with Servo Motors: Control of Servo Motor
MastaMoose
PostPosted: Sat May 09, 2009 5:06 pm     Reply with quote
hi, i am new to both this forum and PIC programing in general. I am using:
-CCS PCM compiler
-2 PIC 16F877
-MPLAB 8.30
So my problem is that i want to control a servo motor, "remotely." What this means is that i want to have two PICs (as mentioned above) that will correspond serially.
Also, the first of said PICs is connected to a potentiometer and will serially transmit the digital data to the second PIC. The second PIC is charged with converting the digitally recieved data to produce a pulse train that will drive a servo motor.
The problem is that my code is sending, and recieving everything okay, but the servo motor does not move. I am sure of the specification however, meaning i am sure that the last code snippet that generates the pulse works on its own when interfaced with a pot through a single chip, but does not work when one chip is input and the other is output.
Masta Moose
MastaMoose
Continued with code
PostPosted: Sat May 09, 2009 5:07 pm     Reply with quote
Here is my code:
Thus I wish to implement potentiometer controller servo motor. The code is as follows:
SENDER CODE:
//Takes pot input and converts it and then sends it out serially
#include <16F877.h>
#use delay(clock = 20000000)
#define ADC = 8
#use rs232 (baud=9600, xmit=pin_c6,rcv=pin_c7, parity=N)
//This is the main function
void main ()
     //This is the code to setup the ADC stuff
     int A2D_Value = 0;
     SET_TRIS_B ( 0x00 );
     setup_adc_ports ( RA0_ANALOG );
     setup_adc ( ADC_CLOCK_INTERNAL );
     set_adc_channel ( 0 );
     DELAY_MS(10);
     //now we are going to send the A2D value of the input serially
        A2D_Value = read_adc(ADC_START_AND_READ);
        putc(A2D_Value);
RECEIVER CODE:
//This code takes the serially transmitted Digtal value and generates a //pulse to control a servo motor
#include <16F877.h>
#define ADC = 8
char timed_getc()
{ //this i changed from char to int
   long timeout;
   timeout=0;
   while(!kbhit()&&(++timeout<50000)) // 1/2
   delay_us(10);
   if(kbhit())
      return(getc());
      return(0);
   char value;
   float value2;
   long x;
      while (TRUE)
        while(!kbhit());
        set_tris_D (0X00);
      value=timed_getc();
        value2=value;
      x = 1250 + (500*value2/256);
        OUTPUT_D (0b11111111);
        DELAY_US(x);
          OUTPUT_D (0b00000000);
          DELAY_US(20000-x);
Masta Moose
bungee-
PostPosted: Sat May 09, 2009 5:20 pm     Reply with quote
Try to put some delay between two transmissions.
And did you try to send fixed values to other pic and did the servo react?
I posted a multi servo code here on forum. You could adapt this code to your needs. The way you are doing it is putting PIC on delay all the time Wink
MastaMoose
PostPosted: Sun May 10, 2009 10:32 am     Reply with quote
okay i tried puting a delay of 20 milliseconds after the sending code and the servo started reacting but i only got a quarter of the range. I will have to check it more on monday when i get back to the lab. So i will update this on monday. Thank you for your help.
Masta Moose
