Receiving package on RS232
Gerhard
PostPosted: Fri May 08, 2009 1:19 pm     Reply with quote
Hi. This might be a silly question but I need to read a scanner into the pic with RS 232. The package looks similar to this +6007762002185.
What function or how should I go about doing it?
I am trying this at the moment but i am only receiving the first character.
#int_rda
void serial_isr()
 chan0=getc();
 chan1=getc();
Any help would be appreciated.
PostPosted: Fri May 08, 2009 2:07 pm     Reply with quote
Look at the Ex_sisr.c file for an example of a serial receive buffer
with the #int_rda interrupt:
c:\program files\picc\examples\ex_sisr.c
Also, does this string have any control characters on the end ?
For example, does it have a Carriage Return (0x0D) at the end ?
If so, then you could use the get_string() function to receive the string.
It's in this file:
c:\program files\picc\drivers\input.c
There is also a version of get_string() that uses the #int_rda interrupt.
It's called bget_string(). It combines the ideas shown in the two
examples above. It's in this example file:
c:\program files\picc\examples\ex_zmd.c
Gerhard
PostPosted: Fri May 08, 2009 2:31 pm     Reply with quote
Thanks.
I have reused that code to see if it will work but i am not getting any data read out on the LCD. I do have the running and buffered part displaying on the lcd though. I know my rs232 port is working and the scanner is working as i can directly read the value into the pc.
This is what I have done using your flex driver combined with the example to test.
#include <18f4680.h>
#device adc=8
#fuses INTRC,NOWDT,NOPROTECT,PUT,NOXINST
#use delay(clock=8M)
#include "flex_lcd.c"
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
    lcd_init();
   enable_interrupts(global);
   enable_interrupts(int_rda);
    printf(lcd_putc,"\rRunning...\r\n");
               // The program will delay for 10 seconds and then display
               // any data that came in during the 10 second delay
   do {
      delay_ms(10000);
      lcd_gotoxy(1,1);
      printf(lcd_putc,"\rbuffered data => ");
      while(bkbhit)
      lcd_gotoxy(1,2);
      printf(lcd_putc, bgetc() );
   } while (TRUE);
Could you maybe off hand see where my mistake is lying and why the value does not want to display? On SIOW the value is +6007762002185. The start bit +. I do not have an end bit in the stream.
PostPosted: Fri May 08, 2009 2:47 pm     Reply with quote
Does the string always have the same number of characters in it ?
Gerhard
PostPosted: Fri May 08, 2009 3:17 pm     Reply with quote
Its a barcode reader but for my purpose yes, as i will be printing the codes myself.
PostPosted: Fri May 08, 2009 4:48 pm     Reply with quote
do {
delay_ms(10000);
What is the purpose of this 10 second delay ?
Your #int_rda buffer is only 32 characters long. If you get two or more
packets during that 10 second interval, you will fill up the buffer and
start to over-write characters from a previous packet (it's a circular
buffer).
lcd_gotoxy(1,1);
The flex lcd driver doesn't recognize the '\r' control character.
Look in the source code for the lcd_putc() function in the driver
to see what control chars it does recognize. You will find the one
that you should be using.
while(bkbhit)
lcd_gotoxy(1,2);
Here you have a loop. As long as characters are available in the
buffer, you just keep setting the x,y coords to the start of the 2nd line.
Your code above is the equivalent of the following:
while(bkbhit == TRUE)
      lcd_gotoxy(1,2);
bkbhit is true if you have chars in the buffer. You need to think about
your logic some more.
