IDE Question - Add Keywords?
Steve H.
PostPosted: Fri May 08, 2009 11:30 am     Reply with quote
I'm running the 4.xxx IDE - Does anybody know how to add keywords to the IDE? I want to add some "uint8_t" kind of stuff to the IDE color syntax recognizer.
Thanks - Steve H.
PostPosted: Wed May 13, 2009 3:52 pm     Reply with quote
I found the answer today while looking for something else... The manual says that you can make a tokens.txt file in the PICC directory to add your own highlighting tokens. It specifies one token per line.
Naturally this does not work in my version (4.032).
Typical!
Steve H.
