maurolarrat
FUSES problem... |
Posted: Wed May 06, 2009 3:55 pm |
I'm using the 30F2010 in a ADC 12 bits project, and I configured a custom project in CCS. CCS created a lot of FUSES, like:
#FUSES WDT128
I commented it with // , and the error got to
setup_adc_ports(AN0|VREF_VREF);
error: undefined identifier. (AN0)
Some one could help me with it? Thanks! |
bungee-
Posted: Wed May 06, 2009 4:22 pm |
You probably commented out
#include <30F2010.h>
FUses and other lines in start of program are there for a reason. |
maurolarrat
Posted: Thu May 07, 2009 10:35 am |
There whmeade has a half the same problem that me...doesn't help :\
but , a simple ADC with dsPIC30F2010 shouldn't be hard to find out here.
I do need just to do a simple read ADC 12 bits, nothing more. Could you help me?
thxs |
FvM
Posted: Thu May 07, 2009 3:41 pm |
The said post answers your question regarding AN0 - so what's your problem?
dsPIC30F2010 however has a 10-Bit rather than 12-Bit ADC. You would need e.g. a dsPIC30F2011. |
maurolarrat
Posted: Fri May 08, 2009 9:50 am |
Sorry my fault FvM, you are right. I really will use the 2011.
thanks! |
maurolarrat
Posted: Fri May 08, 2009 12:59 pm |
I made like this:
#include <30F2011.h>
#device adc=12
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV27 //Brownout reset at 2.7V
setup_adc_ports(sAN0|VSS_VDD);
setup_spi(SPI_SS_DISABLED);
SETUP_TIMER1(TMR_DISABLED);
SETUP_TIMER2(TMR_DISABLED);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// TODO: USER CODE!!
I only want use the ADC of 30F2011, if the code has some fuses or setup that I forgot to put there, please could you correct to me? But it compiled good enough. |
