Error BAUD RATE 30f2020
Orcino
PostPosted: Thu May 07, 2009 7:02 am     Reply with quote
Hi im my code below, i config the baud rate for 9600, but in hiperterminal work 19200. Any help ?
Thanks in advance
#include <30F2020.h>
#device ADC=10
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOCPB                    //No Boot Block code protection
#FUSES FRC_PLL                  //Internal Fast RC oscillator with PLL
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES FRANGE_HIGH
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES NOPR                     //Pimary oscillaotr disabled
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES PUT128                   //Power On Reset Timer value 128ms
//#FUSES ICSP1                    //ICD uses PGC1/PGD1 pins
#use delay(clock=30Mhz)
#use rs232(UART1,baud=9600,parity=N,bits=8)  //<------------------------
PostPosted: Thu May 07, 2009 11:57 pm     Reply with quote
What makes you assume a clock frequency of 30 MHz? As far as I see, FRC_PLL + FRANGE_HIGH results in a clock frequency of 4*14.55 = 58.2 MHz.
Orcino
PostPosted: Fri May 08, 2009 10:32 am     Reply with quote
Is really, thanks.
Orcino
