16f877 eeprom problem
Minky
PostPosted: Wed May 06, 2009 8:30 am     Reply with quote
Hi! I'm having some problems getting data from a function "bgetc" to an array "Log" and then write it down to the 16f877s internal eeprom. I know the LCD is working and I can get the string "Temp" out on the lcd, but I can't get the buffer-data out on the lcd for some reason. I would very much appreciate any feedback I can get!
#include <16F877.H>
#device *=16
#use delay(clock = 12M)
#org 0x1F00, 0x1FFF void loader16F877(void) {} //for the 8k 16F876/7
#include <flex_lcd.c>
#define BUFFER_SIZE 4
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer är full!
BYTE bgetc() {
   BYTE c;//
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
   int a=0;
   int j=0;
   int8 k;
   int8 buffer[5];
   int8 q;
   BYTE Log[5];
   lcd_init();  // Call lcd_init...
   enable_interrupts(int_rda);
   enable_interrupts(global);
   while(1) {
      lcd_putc("\f");
      lcd_putc("Temp:");  // put "Temp:" on LCD
      while(bkbhit)
      if (a==10)     // an if-case to save every 10:th value to a log
            Log[j] = bgetc();  // save the value from the bgetc function to the array Log[j]
            j++;               // increment the J variable to get to next poss in the array
            if(j > 4)j =0;     // reset the counter once you reach the end of the array
            a=0;               // reset the a variable to be able to save the next "10:th" value
            for(k = 0; k < sizeof(Log); k++)   // write values in the array "Log" to the eeprom mem. pos 0-5
            write_eeprom(k, Log[k]);
            for(k = 0; k < sizeof(Log); k++)   // read the values in eeprom (mem. pos) to the array "buffer"
            buffer[k] = read_eeprom(k);
            if (j==4)     // if the array (Log) is full, then print the values with a 2 sec delay on the LCD
               for (q=0;q==4;q++)
               lcd_putc(buffer[q]);  // print the array to LCD
              delay_ms(2000);
      a++;
      delay_ms(3000);
PostPosted: Wed May 06, 2009 10:26 am     Reply with quote
for (q=0;q==4;q++)
delay_ms(2000);
Look at your test in the for() loop.
