MMC initialization Set Block Length
gbie
PostPosted: Tue May 05, 2009 12:07 am     Reply with quote
my initialization stopped working. when i send CMD16, i get a R1 response of 00000111, which means illegal command + erase/reset + idle?
      // Got out of idle response
      SPI_WRITE(0xFF);                        // extra clocks to allow mmc to finish off what it is doing
      output_low(PIN_C2);                     // set SS = 0 (on)
      SPI_WRITE(0x50);                // send mmc command1 to bring out of idle state
      SPI_WRITE(0x00);
      SPI_WRITE(0x00);
      SPI_WRITE(0x02);                // high block length bits - 512 bytes
      SPI_WRITE(0x00);                // low block length bits
      SPI_WRITE(0xFF);                // checksum is no longer required but we always send 0xFF
      count = 0x05;
     response = 0xFF;
      while(response !=0x00 && count >1){
      response = SPI_READ(0xFF);
      --count;
    if (response ==0x00){       //if correct response
     output_high(PIN_C2);
      return (0);
   } else {
      return(3);
could this have to do with formatting the mmc card with my PC and a card reader?
gbie
PostPosted: Tue May 05, 2009 12:45 am     Reply with quote
Actually, I see that I'm getting a response in the middle of a command.
I send CMD0, get 0x01. Good.
I send CMD1, after 2 tries, I get 0x00. Good.
I send CMD16, I get a 0x07 response in the middle of the command.
I send CMD16 against afterwards and can get a correct 0x00 response.
gbie
PostPosted: Tue May 05, 2009 1:19 am     Reply with quote
I got the right responses by adding more clock cycles between commands.
Next problem: I can't get the data block response after a write anymore. I do get a busy signal though. A long block of 0x00. Except the last one. That's 0x07. :(. well, it looks like my response is 0xE0 instead of E5.
PostPosted: Tue May 05, 2009 4:07 am     Reply with quote
Seems, as you should pay more attention to the MMC protocol specification.
