ADC decimal Digit problem
ailatech
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Sun May 03, 2009 3:13 pm     Reply with quote
Hi all
I have a problem with adc
I want to display a float number consists of 3 decimal digits at least, i tried to use the following:
set_adc_channel( 0 )
delay_us(10);
x=read_adc();
y=x/100;
printf("X=%u Y=%1.3f \r\n",x,y);
But i still get 1.000 or 2.000 only without decimal digits
Eng. Haytham Shyouk
B.A. Electronics Engineering
PostPosted: Sun May 03, 2009 3:52 pm     Reply with quote
y=x/100;
You are doing integer math. If you divide one integer (x) by another
integer (100), the result is an integer.
If you want a floating point result, you must make one of the numbers
in the divison expression into a float. Example:
y=x/100.0;
You didn't show any of your variable declarations. 'y' should be declared
as a 'float'. 'x' should be declared as an 'int16' if you are using the A/D
in 10-bit mode. Also, if 'x' is an 'int16', then you should use "%lu" to
display it in printf.
