Problem my code with 16f722
RECARDO
PostPosted: Sat May 02, 2009 4:31 pm     Reply with quote
Hi.
I do not use PORTA.3 PORTA.4 and PORTA.5 ports. fOR EXAMPLE
if (input(PIN_A2)){CLed=1;} else {CLed=0;} LED oK
if (input(PIN_A3)){DLed=1;} else {DLed=0;} LED İS NOT LIGHTING
if (input(PIN_A4)){ELed=1;} else {ELed=0;} LED İS NOT LIGHTING
if (input(PIN_A5)){FLed=1;} else {FLed=0;} LED İS NOT LIGHTING
pLEASE HELP ME
My code is here;
#include <16F722.h>
//#device adc=8
#FUSES INTRC_IO, NOMCLR, PUT, NOWDT, PROTECT, NOBROWNOUT, NOPLLEN, NODEBUG, NOVCAP   //No Watch Dog Timer
#use delay(clock=16000000)
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#byte    PORTA   = 0x05
#byte    PORTB   = 0x06
#bit  Cinput =  PORTA.2  //input
#bit  Dinput =  PORTA.3  //input
#bit  Einput =  PORTA.4  //input
#bit  Finput =  PORTA.5  //input
#bit  CLed   =  PORTB.2  //out
#bit  DLed   =  PORTB.3  //out
#bit  ELed   =  PORTB.4  //out
#bit  FLed   =  PORTB.5  //out
#int_RTCC
void  RTCC_isr(void)
{  setup_oscillator(OSC_16MHZ);
   setup_adc(ADC_OFF);
   setup_spi(SPI_SS_DISABLED);
   setup_vref(FALSE);
   port_b_pullups(TRUE);
   SET_TRIS_A(0b11111111);SET_TRIS_B(0b00000000);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);  // 4Ms
   setup_timer_1(T1_DISABLED); setup_timer_2(T2_DISABLED,0,1);
   enable_interrupts(INT_RTCC);
   Delay_Ms(100);
   While(True)
