#device 16F54 *=16
jworam
#device 16F54 *=16
PostPosted: Sat May 02, 2009 11:43 am     Reply with quote
Using the directive #device 16F54 *=16 does not seem to work for 16F54 chips. (using MPlab 7.0 )
// C static global variables
unsigned  char ms_cntr;
unsigned  char seconds;
unsigned  char minutes;
unsigned  char hours;
unsigned  char delay_timer;  //
unsigned  char timer_9V_read;
unsigned  char timer_9V_beep;
unsigned  char trigger_9V_chirp_flag;
unsigned  char Chirp_timer_9V;
unsigned  char RTCC_trip_value;
unsigned  char beep_toggle_timer;
unsigned  char OP_toggle;
unsigned  char excess_alarm;
unsigned  char pump_state;
unsigned  char AC_alarm;
unsigned  char Alarm_9V;
unsigned  char alarm_state_9V;
unsigned  char beep_state;
unsigned  char pump_timer;
unsigned  char offtimeflag;                 //  4/28/2009
unsigned  char pump_antilock_minute_timer;  //
unsigned  long pump_accru_timer;
end of variables
PostPosted: Sat May 02, 2009 12:26 pm     Reply with quote
For the PCB compiler, you would use
#device *=8
But it's not necessary. The 16F54 only has 25 bytes of user RAM and it's
all in one page. The compiler reserves 2 bytes for its own purposes.
Apparently there is a quirk, where if you declare a 'long' variable it
wants to reserve even more. I was able to work around the problem
by changing the long into two byte variables. See below.
It's possible that you could work around the problem by using the
#locate directive, which tells the compiler the exact RAM address
to use for each variable. I didn't try that.
#include <16F54.h>
#fuses XT, NOWDT, NOPROTECT
// unsigned long pump_accru_timer;
int8 temp0;
int8 temp1;
jworam
#device *=8
PostPosted: Sat May 02, 2009 1:59 pm     Reply with quote
Thanks for the most helpful tip.
I could never get anything to compile or even tell if it is using the PCB compiler. But once I stripped out enough variables, it did compile.
I opened the list file and saw that it did use the PCB compiler.
Now I have some how got to make the program work with this limited memory.
I bought it from CCS last year and have never got it to work until now.
Thanks so much,
Jworam
