Weak Pull-Ups on a 16F684 [solved]
/dev/human
PostPosted: Fri May 01, 2009 12:15 am     Reply with quote
Hi Folks,
on a 16F684 I want to use the weak pull-ups on A4 and A5 (A0 to A3 are analog inputs).
A HW check shows that they are turned off, adding 1 Meg to Vdd proved the HW to be working.
What I did in SW is to use:
port_a_pullups (0b00110000);
or
#define OPTION 0x81
#define WPUA   0x95
*OPTION |= 0b10000000;                          // Enable weak pull-ups for ports A
*WPUA = 0b00110000;                             // Set weak pull-ups for port A5, A4
Simulating the below code WPUA and OPTION are set correctly but the HW is still not working as expected.
Any ideas?
Never check your brain at the door!
RLScott
Re: Weak Pull-Ups on a 16F684
PostPosted: Fri May 01, 2009 4:57 am     Reply with quote
Have you configured A4 and A5 as digital inputs? (in which case you should probably call them by their port pin names rather than A4 and A5) The weak pull-up will not work if they are still left at their default configuration as analog inputs.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
/dev/human
PostPosted: Fri May 01, 2009 10:58 am     Reply with quote
Yes RA3 to RA5 are digital inputs. I'm aware the RA3 needs an external pull-up. I checked the code and the result with MPLAB. According MPLAB the SFR ANSEL is 0b00000111. WPUA is 0b00110111, OPTION is 0b11000001. This is all I can think of to enable weak pull-ups. Checking the input signals with a scope, I can only see correct signals (open collector driver) when at least 1 M or better 100 k is attached externally.
Man, I'm stupid, while re-reading the entry, I recognize I need to clear -RAPU.
Addendum: and yes, it works! Very Happy
