Hello everyone. I want to develop a board using PIC18F4580 with a Transmission oil pressure sensor connected at AN0 and convert the analog value to CANbus signal (extended format) which will be viewed on PowerView Display(CANBUS enabled Display Device). Can anybody say what should be the basic board layout and software code? Plz reply.
Thanks for reply. Can you please send me the program (written in PIC C compiler) using PIC18F458 & MCP2551 which produce CAN signal as output and uses analog signal as input. (Precisely,an analog pressure sensor is connected at PORT AN0.)
Posted: Wed Apr 29, 2009 10:21 pm
No, I will not do your project for you. You need to write the code.
