PIC Code Help
Leon
PIC Code Help
PostPosted: Wed Apr 29, 2009 3:06 pm     Reply with quote
I am working on a project for my class. The hardware part of the project is completed, and we have a working prototype with 1 sensor input.
This means that our PIC MC is programmed for one input but we need a total of three. Currently the data input is serial analog, the MC converts it to digital and sends it to a transmitter. On the receiver end, the MC is programed to take the incoming data and convert it into parallel output which, using a DAC, is converted back into analog.
I have searched and searched for information on how to program the MC so that 3 inputs can be used. The three inputs have to be turned into serial data which is transmitted to the receiver. On this side, the MC has to take the data and output it in parallel for the DAC to convert back to analog.
The MicroController is: PIC16F688
Compiler: PICkit2
Thank you for any help!
The current code for transmitter side:
#include <p16F688.inc>
   __CONFIG    _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_OFF & _WDT_OFF & _HS_OSC
     org 0
Start:
; Initialize registers
;   bsf      STATUS,RP0   ; select Register Bank 1
;   bcf      TRISA,0      ; make IO Pin RD0 an output
;   bcf      STATUS,RP0   ; back to Register Bank 0
   BSF      TRISA,0
   BSF      ANSEL,0
   bcf      STATUS,RP0   ; select Register Bank 0
   BSF      RCSTA,7
; Configure ADCON0,ADCON1
   MOVLW   B'00000001'
   MOVWF   ADCON0
   MOVLW   B'00000000'
   MOVWF   ADCON1
; Configure TXSTA
   MOVLW   B'10100010'
   MOVWF   TXSTA
; Configure SPBRG
   MOVLW   B'10000001'
   MOVWF   SPBRG
; Configire BAUDCTL
   MOVLW   B'01000000'   ; The transmit problem was here.  If bit 0 is a 1, transmitter won't work
   MOVWF   BAUDCTL
MainLoop:
   bsf      ADCON0,1   ; Start conversion
   btfsc   ADCON0,1
   goto   $-1
   ; result in ADRESH
   MOVF    ADRESH,0
   ;MOVLW   b'00010010'   ; For debugging
   MOVWF   TXREG
   goto   MainLoop   ; Do it again...
   end
The Receiver side MC:
; Make sure MPLAB is configured correctly
;    - Choose the correct PIC
;       - Go to Configure - Select Device
;       - Select PIC16F688
;    - Choose the correct programmer
;       - Go to Programmer -> Select Programmer -> PICkit 2
; To load program onto PIC:
;    - Go to Project -> Quickbuild
;    - If no errors occur, download the code (*note there is a limit to the length of the filename, will cause error)
;       - Go to Programmer -> Program
;    - If no errors, remove the chip and place in circuit
TEMP equ 0x20
   __CONFIG    _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_OFF & _WDT_OFF & _EC_OSC
     org 0
Start:
;Configure TRISA
   bsf      STATUS,RP0   ;select Register Bank 1
   MOVLW   B'00000000' ;Make outputs
   MOVWF   TRISA
;Configure TRISC
   MOVLW   B'00100000' ;Make only RC0:4 Outputs as RC 5 is needed for Reciever
   MOVWF   TRISC
;Configure ANSEL
   MOVLW   B'00000000' ; Set as Digital Signals
   MOVWF   ANSEL
;Configure PIE1
;   bsf      STATUS,RP0   ;select Register Bank 1
;   MOVLW   B'00100000' ;Allows Interrupt on Reciever
;   MOVWF   PIE1
;Configure INTCON
;   MOVLW   B'11000000' ;Allows Reciever Interrupt to Enable
;   MOVWF   INTCON
; Configure TXSTA
   MOVLW   B'10000010'
   MOVWF   TXSTA
; Configure SPBRG
   MOVLW   B'10000001'
   MOVWF   SPBRG
; Configire BAUDCTL
   MOVLW   B'01000000'
   MOVWF   BAUDCTL
; Configure RCSTA
   bcf      STATUS,RP0 ;select Register Bank 0
   MOVLW   B'10010000'
   MOVWF   RCSTA
; Configure CMCON0
   bcf      STATUS,RP0
   MOVLW   B'00000111'
   MOVWF   CMCON0
MainLoop:
   btfss PIR1,5 ;Check bit 5 for full interrupt flag
   goto $-1
;   MOVLW B'10010011' ; Debugging
   MOVF RCREG,0
   MOVWF TEMP      ; Move data to Temporary
   MOVWF PORTA      ; Move data to PORTA bits 2,1,0
   ; Move data bit 7 to PORTA,4
   BTFSS TEMP,7
   BCF PORTA,4
   BTFSC TEMP,7
   BSF PORTA,4
   ; Rotate and move to PORTC bits 3,2,1,0
   RRF TEMP,1 ;Rotate working register 3 times
   RRF TEMP,1
   RRF TEMP,1
   MOVF TEMP,0   ;Move High bits to Working Register
   MOVWF PORTC ;Write 5 High Bits to port C's Low 5 Bits
   end
Leon
PostPosted: Wed Apr 29, 2009 3:09 pm     Reply with quote
Project schematic:
http://es242-digitalhealth-s09.wikispaces.com/file/view/schematic.jpg
The receiver MC has 8 channel output, even though only 3 are pictured (have to update)
Your code is written in MPASM. This forum is about the CCS C compiler.
You should ask your question in a PIC forum that uses MPASM.
Here is a link:
http://www.microchip.com/forums/tt.aspx?forumid=11
Leon
Re: PIC Code Help
PostPosted: Wed Apr 29, 2009 3:14 pm     Reply with quote
Thank you for quick response, and for pointing me in the right direction. This could explain why I could not find anything, looking under wrong code.
Thank you again
