w2drz
Joined: 27 Dec 2006 Posts: 55 Location: Western New York - USA
Programmer failure ICD-U40 [solved] |
Posted: Wed Apr 29, 2009 8:58 am |
Just a note on if the programmer U40 has a strange failure to work,
I just had a U40 fail to work correctly, as had a second U40 was able to finish what was doing but the failed unit could not recover that unit so ordered a new U64 but in meantime see there is a new CCSLOAD program so load that and play with it, see there is a new:
Download USB Drivers for ICD-UXX/Mach X/Load-n-Go/PRIME8
(Windows) (12.06.06)
Load that driver and using the failed "U40" programmer was playing with a new HEX file program on a PICC test/proto engineering unit.
U40 is now working so just a heads up note.
tom W2DRZ |
