LCD on PICDEM 2 PLUS with PIC16Fxx
snwbnd
PostPosted: Wed Apr 29, 2009 1:27 am     Reply with quote
I'm using a PIC16Fxx Device and the PICDEM 2 Plus Board. Im tried to use the flex_lcd.c Code with some modification to use the LCD.
I'm using the 18-Pin Socket, which has no connection to the lcd. Because of that I connect it with cables over the other two sockets:
28-PIN-Socket        40-PIN-Socket
21 -> 19
22 -> 20
23 -> 21
24 -> 22
25 -> 27
26 -> 28
27 -> 29
28 -> 30
In the flex_lcd I've corrected the beginning part with port declaration:
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver.  Change these
// pins to fit your own board.
#define LCD_DB4   PIN_B0
#define LCD_DB5   PIN_B1
#define LCD_DB6   PIN_B2
#define LCD_DB7   PIN_B3
#define LCD_E     PIN_B6
#define LCD_RS    PIN_B5
#define LCD_RW    PIN_B4
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
// #define USE_LCD_RW   1
No I hopped this should work with the following code in the main.c:
   output_high(LCD_POWER);  // Turn on power to LCD
   output_low(LCD_RW);      // Set R/W pin on LCD to a low level
   lcd_init();  // Always call this first.
   lcd_putc("\fHello World\n");
   lcd_putc("Line Number 2");
What's wrong? Can somebody help or have somebody also tried to use a PIC16 Device with the LCD?
PostPosted: Wed Apr 29, 2009 11:01 am     Reply with quote
First, I need to know which version PicDem2-Plus you have.
The new Rohs version looks like this. It has silver pads in the bottom of
the prototyping area on the right side of the board:
http://www.microchipdirect.com/ProductSearch.aspx?Keywords=DM163022
The older non-Rohs version doesn't have that. It looks like this:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en010072
Which board do you have ?
snwbnd
PostPosted: Wed Apr 29, 2009 11:07 am     Reply with quote
I have the new Rohs Version from 2006!
Since i've wrote the thread, I've changed some pins. I saw that RB6 and 7 are used for Debugging and RB0 is connected to S3.
RA1...RA3 -> RS, R/W and E
RB1...RB4 -> DB4...DB7
RB5 -> VCC Transistor to activate the Display
This connections are made and tested on the hardware
in the flex_lcd I've wrote this:
#define LCD_DB4   PIN_B1
#define LCD_DB5   PIN_B2
#define LCD_DB6   PIN_B3
#define LCD_DB7   PIN_B4
#define LCD_E     PIN_A3
#define LCD_RS    PIN_A1
#define LCD_RW    PIN_A2
In main.c I've added this:
#define LCD_POWER  PIN_B5
PostPosted: Wed Apr 29, 2009 11:13 am     Reply with quote
Post your PIC and your compiler version.
snwbnd
PostPosted: Thu Apr 30, 2009 2:11 am     Reply with quote
CCS Version 4.057
MPLAB Version 8.00
PIC16F87
PostPosted: Thu Apr 30, 2009 12:12 pm     Reply with quote
You jumpered Port B to Port D on a 1:1 basis. The LCD uses pins
on Port D only. The connections are shown in the schematic in the
back of the PicDem2-Plus User's Guide. So to create the new #define
statements, you simply have to edit the table shown in this post
http://www.ccsinfo.com/forum/viewtopic.php?t=24661&start=51
and change PIN_Dx into PIN_Bx. Also, the #define for the power pin
should be changed in the same way. Do it like this:
#define LCD_RS    PIN_B4
#define LCD_RW    PIN_B5
#define LCD_POWER  PIN_B7
If you copy this code exactly, it should work. But to be safe, remove
jumper J6. There are 4 LEDs on pin B0 to B3. It's possible that these
might interfere with the LCD operation if they are connected. If you
remove jumper J6, they will be disabled.
snwbnd
PostPosted: Thu Apr 30, 2009 12:24 pm     Reply with quote
No, I jumpered it like this:
I removed J6 and I don't want to usw RB0 because of the connection to the RB0 Button and RB6&7 because they are used for the Debugger....
I've changed the code like my post before:
Also the Power Pin is changed!
PostPosted: Thu Apr 30, 2009 12:30 pm     Reply with quote
So you changed the jumpers ? Here is your previous list of jumpers.
21 -> 19
22 -> 20
23 -> 21
24 -> 22
25 -> 27
26 -> 28
27 -> 29
28 -> 30
Apparently this is no longer in effect.
Post the exact list of pin-to-pin jumpers (not names) that you currently have.
snwbnd
PostPosted: Thu Apr 30, 2009 12:36 pm     Reply with quote
At the moment, I've released the connections to test the lcd with a 40pin device, which is working perfectly by the way.
I've always made the connections from the 40pin to the 28pin socket and after I've tested them with a multimeter. Directly measured from my 16f87 and the LCD Connections.
Did you ever used the lcd on the picdem 2 with a 18pin PIC device?
PostPosted: Thu Apr 30, 2009 12:38 pm     Reply with quote
No.
snwbnd
PostPosted: Thu Apr 30, 2009 12:43 pm     Reply with quote
So I test it tomorrow again, the connections are correct...
Do you think it should work like I said here:
PostPosted: Thu Apr 30, 2009 12:52 pm     Reply with quote
It will probably work, provided that it's jumpered correctly.
