pull up on some B-pin
sliders_alpha
PostPosted: Tue Apr 28, 2009 2:10 pm     Reply with quote
hi,
I want pull up on B0 and B5 on a 16F876A under CCSV4.057.
Should I do this : port_b_pullups (0b00100001);
I have a lot of stuff wired on port b, just checking, I don't want to destroy a pin.
yup, i know, i don't speak english very well
CCS V4.057
bungee-
PostPosted: Tue Apr 28, 2009 2:34 pm     Reply with quote
Try without wired stuff Wink
sliders_alpha
PostPosted: Tue Apr 28, 2009 2:42 pm     Reply with quote
it's an smd board, everything is soldered and i forgot to put two pull up :/
CCS V4.057
PostPosted: Tue Apr 28, 2009 3:03 pm     Reply with quote
Read the PIC data sheet. Secton 4.2 says:
Each of the PORTB pins has a weak internal pull-up.
A single control bit can turn on all the pull-ups.
There is no individual control of bits.
Read the PIC data sheet. Section 17.2 says:
PORTB Weak Pull-up Current: Min:50 µA Typ:250 µA Max:400 µA
This gives a typical pull-up of 20K ohms.
Also, internal pull-ups only work when the pin is set to be an input pin.
Secton 4.2 of the data sheet says:
The weak pull-up is automatically turned off when the port
pin is configured as an output.
sliders_alpha
PostPosted: Tue Apr 28, 2009 3:46 pm     Reply with quote
alright, thanks a lot, i'm going to put "real" pull up then
CCS V4.057
