Currently I'm working on navigating using optical mouse. I already constructed my circuit using PIC16F877A. Its RX and TX pin already connected to max232. I bought a coprocessor pak-xi from william. This coprocessor will handle the communication protocol. The usb mouse will connect directly to the coprocessor. How can I send the data from the coprocessor to the PIC? The pak-xi has TX and RX pin. Someone told me that I should use uart software. How can I use it?
