RF CCS Problem
arunkish
RF CCS Problem
PostPosted: Mon Apr 27, 2009 8:05 pm     Reply with quote
Hi All
I have a problem with RF Receiving Section. To tell you in depth. I had a code written in assembly that works perfectly and receives the data. I have rewritten the same code in CCS and that fails to work. I really can't find what the problem is and where the problem is. I guess there are some problems with the delays. I have the assembly and the converted CCS code below. Please can someone tell me where I have made the mistake.... Thanks in advance.
ASSEMBLY CODE
#define XTAL       .4000000
#define RF_NBITS    .64
#define RF_Full   RXFlags,0     ; receive buffer full
#define RFBit     RXFlags,1     ; sampled input value
TX_BUFF      equ   0x40
RX_BYTE_PTR  equ   0x40
 CBLOCK   RX_BYTE_PTR
      rx_byte1
      rx_byte2
      rx_byte3
      rx_byte4
      rx_byte5
      rx_byte6
      rx_byte7
      rx_byte8
        RFP             ;
        RFbitc          ;
        RFsamp          ;
        RFState         ;
        RFSkip          ;
        RXFlags         ;
        pul_cnt
        BIT_CNT
        ERR_NO
 ENDC
IntVector
            movwf   W_TEMP          ; must have been placed in common bank
            swapf   STATUS,W
            movwf   STATUS_TEMP     ;
            BANK0
Async_ISR
            movlw   .50
            subwf   TMR0,F
            bcf     INTCON,T0IF     ; interrupt served
; sample RF input pin
            bcf     RFBit
            btfsc   RFIn
            bsf     RFBit
AsyncRF
            btfss   INTCON,INTE
            goto    CHK_SKP
            btfsc   INTCON,INTF
            goto    SKP1
CHK_SKP
            decf    RFSkip,F
            BNZ     ExitIntShort    ;
SKP1
            btfsc   RF_Full
            goto    ExitIntShort
            movf    PCLATH,W        ; save PCLATH since we will use tables here
            movwf   PCLATH_TEMP
AsyncStateM
            clrf   PCLATH         ; we assume this routine has been placed in page 0
            movf    RFState,W
            andlw   07
            addwf   PCL,F
RFTable
            goto    TRFSYNC
            goto    TRFHALF
            goto    TRFBIT
            goto    TRFZERO
            goto    TRFCLOCK
            goto    RFRestore
            goto    RFRestore
            goto    RFRestore
RFTableEnd
TRFSYNC
            btfss   INTCON,INTE
            goto    RDIN
            btfsc   INTCON,INTF
            goto    TRFRise
RDIN
            btfsc   RFBit           ;
            goto    TRFRise
            incf    RFsamp,F        ;
            incf    RFSkip,F        ;
            btfsc   INTCON,INTE      ;
            goto    EXIT_INT
;Check min
            movlw   .35
            subwf   RFsamp,W
            btfss   STATUS,C
            goto    EXIT_INT       ; check if valid preamble then nable int
           bsf       INTCON,INTE
              bcf      INTCON,INTF
;            bsf     LED2
            goto    EXIT_INT
TRFRise
           btfss   INTCON,INTE
            goto    RFRestore       ;
           bcf     INTCON,INTE
              bcf      INTCON,INTF
            movlw   .50
            subwf   RFsamp,W
            btfsc   STATUS,C
            goto    RFRestore
            movf    RFsamp,w
            movwf   pul_cnt
; make ready for receiving the first bit
            clrf    RFbitc
            movlw   RX_BYTE_PTR
            movwf   RFP
            movlw   .2
            movwf   RFSkip          ;
            incf    RFState,F
;            bcf     LED2
            goto    AsyncRFE
TRFHALF
            btfss   RFBit
            goto    RFRestore1
TRFNEXT     movlw   D'04'           ; set a delay of a full bit ie 400us
TRFSKIP     movwf   RFSkip          ;
            incf    RFState,F       ; move on to next state
            goto    AsyncRFE
TRFBIT
            movf    FSR,W           ; save FSR
            movwf   FSR_TEMP
            movf    RFP,W
            movwf   FSR             ; point to current buffer
            CLRC
            btfss   RFBit           ; copy in bit (inverted)
            SETC
            rrf     INDF,F          ; rotate in buffer (Lsb first-> rotate right)
            incf    RFbitc,F        ; count bits
            movf    FSR_TEMP,W      ; restore FSR
            movwf   FSR
            goto    TRFNEXT         ; move on next state
TRFZERO
            btfsc   RFBit            ; end bit check fails
            goto    RFRestore3       ;
            movlw   7
            andwf   RFbitc,W        ; 8 bit read in?
            SKPNZ
            incf    RFP,F           ; next byte
            movlw   RF_NBITS
            subwf   RFbitc,W        ; riceived them all?
            BZ      TRFFULL         ;
; not yet finished, resync on next rising edge
TRFZN
           bsf       INTCON,INTE     ;ENABLE EXTERNAL INTERRUPT
              bcf      INTCON,INTF      ;CLR INTERRUPT FLAG
            movlw   D'3'            ; next state without delays (skip=1)
            movwf   RFSkip          ;
            incf    RFState,F       ; move on to CLOCK
            clrf    RFsamp          ; init resync counter
            goto    AsyncRFE
TRFFULL     bsf     RF_Full         ; buffer full and ready
           bcf       INTCON,GIE     ;ENABLE EXTERNAL INTERRUPT
            goto    RFRestore
TRFCLOCK
           bcf       INTCON,INTE     ;DISABLE EXTERNAL INTERRUPT
              btfss   INTCON,INTF      ;CLR INTERRUPT FLAG
            goto    RFRestore4      ;   too long delay
;            btfss   RFBit           ; waiting for rising edge
;            goto    RFRestore4      ;   too long delay
            movlw   .205
            movwf   TMR0
            movlw   .02
            movwf   RFSkip          ;   set delay 1/2Te
            movlw   1               ;   move on to start bit state (1)
            movwf   RFState         ;
            goto    EXIT_INT
;debugging point
RFRestore4
            bsf     ERR_FLAG
            goto    RFRestore      ;next start bit error
RFRestore3                         ;low bit error
            clrf    ERR_NO
            bsf     ERR_FLAG
;            bsf     DERR_LED
            goto    RFRestore
RFRestore2                         ;mid bit error
RFRestore1
            movlw    0xff
            movwf   ERR_NO
            bsf     ERR_FLAG
;            bcf     DERR_LED       ;High bit error
            goto    RFRestore
;           nop                     debugging point
RFRestore
;            bsf     LED2
            movf    RFbitc,w
            movwf   BIT_CNT
            clrf    RFState         ; reset state machine
            movlw   .1
            movwf   RFSkip          ; preload skip 1
            clrf    RFsamp
AsyncRFE
EXIT_INT
            movf    PCLATH_TEMP,W   ; restore PCLATH
            movwf   PCLATH
ExitIntShort
            swapf   STATUS_TEMP,W   ; restore context
            movwf   STATUS
            swapf   W_TEMP,F
            swapf   W_TEMP,W
            retfie                  ; exit re-enable interrupts
InitRX
            clrf    RFState     ; init receiver
            clrf    RXFlags
            movlw   .1
            movwf   RFSkip      ; no delays
            clrf    RFsamp      ;
            return
INIT_TIMER0
          banksel   TMR0
         movlw       D'205' ;                LOAD VALUE FOR 100 MICRO SECONDS
        movwf       TMR0
          banksel   OPTION_REG
        movlw       B'10000000'
        movwf      OPTION_REG           ;TIMER0 PRESCALER = 1:1,INTERNAL CLOCK & TIMER ON 200us
          bsf       OPTION_REG,INTEDG    ;INTERRUPT ON RISING EDGE OF RB0\INT
          clrf      INTCON
         bsf      INTCON,T0IE           ;ENABLE TIMER0 INTERRUPT
         bcf       INTCON,INTE           ;DISABLE EXTERNAL INTERRUPT ENABLE
          BANK0
          return
CCS CODE
#include<12f675.h>
#fuses NOBROWNOUT,NOWDT,INTRC_IO,NOPROTECT,NOMCLR,PUT
#define      PRODUCT_ID        0xaa  //1.PRODUCT CODE 0xaa
#define      DEVICE_ID       0x03  //2.SMOKE DETECTOR
#define      PANEL_SL_HIGH    0x0b  //3.SLNO HIGH 0-255
#define      PANEL_SL_LOW    0x0b  //4.SLNO LOW  0-255
#define      SL_NO_HIGH       0x00  //5.SLNO HIGH 0-255
#define      SL_NO_LOW       0x01 //6.SLNO HIGH 0-255
void data_check(void);
void pwm(void);
#BYTE  OPTION_REG = 0X81
#byte INTCON   =   0x0B
#byte GPIO      = 0x05
#byte gpio_tris = 0x85
#bit RX_PIN       = GPIO.2
#bit siren    = GPIO.0
#bit led    = GPIO.1
#bit INTE      =  INTCON.4
#bit GIE      =  INTCON.7
#bit INTF      =  INTCON.1
#bit EDGE      = OPTION_REG.6
byte pre,count,data,rx_data[8],i,rx_and,status;
long int k,j;
#bit data_hed=status.0
#bit tx_and=status.1
#bit int_dly=status.2
#bit data_che=status.3
#zero_ram
gpio_tris=0x3c;
GPIO=0X00;
data=0;
count=0;
pre=0;
GIE=1;
INTE=1;
INTF=0;
EDGE=1;
tx_and=0;
int_dly=1;
data_hed=0;
data_che=0;
rx_and=0x01;
for(i=0;i<=7;i++)
rx_data[i]=0;
led=1;
led=0;
i=0;
j=0;
k=0;
         data_check();
         pwm();
#INT_EXT
void ext(void)
INTE=0;
    INTF=0;
   GIE=0;
if(pre<16)
delay_us(400);
++pre;
if(pre==16&&data_hed==0)
delay_us(4405);
data_hed=1;
if((pre==16)&&(data_hed==1))
delay_us(401);
if(!RX_PIN)
rx_data[data]=rx_data[data]|rx_and;
rx_and = rx_and<<1;
count++;
if(count==8)
rx_and=0x01;
count=0;
data++;
if(data==8)
   if(rx_data[0]==PRODUCT_ID)
      data_che=1;
      delay_ms(600);
      INTE=0;
         data=0;
         pre=0;
         data_hed=0;
      return;
      for(i=0;i<=7;i++)
      rx_data[i]=0;
data=0;
pre=0;
data_hed=0;
   INTE=1;
    GIE=1;
   if(data_che)
      if(rx_data[1]==DEVICE_ID)
               if(rx_data[5]==SL_NO_LOW)
               tx_and=1;
               led=1;
   else if(rx_data[1]==0x05){tx_and=0;siren=0;led=0;}
data_che=0;
for(i=0;i<=7;i++)
rx_data[i]=0;
   INTE=1;
    GIE=1;
void pwm(void)
byte i;
if(tx_and)
while(i!=500)
siren=1;
delay_us(500);
siren=0;
delay_us(500);
i++;
i=0;
while(i!=500)
siren=1;
delay_us(500);
delay_us(250);
siren=0;
delay_us(500);
delay_us(250);
i++;
i=0;
bungee-
PostPosted: Tue Apr 28, 2009 12:22 am     Reply with quote
I quickly look at the code and first thing I saw that is not good, well is really bad actually, you use delays in ISR.
So it is no wonder that your PWM part is not working like it should. Try to rewrite whole thing. Use Timer ISR for PWM, that would be probably best practise.
arunkish
PostPosted: Tue Apr 28, 2009 1:06 am     Reply with quote
Thank you for your response. I didn't give much prefrence to the PWM part at this time. I just want the RX to work properly. Hopefully I will be correcting the PWM as you said.
bungee-
PostPosted: Tue Apr 28, 2009 2:03 am     Reply with quote
Do you use rs232 protocol for reception or is this another protocol for receiving serial data?
You could use port A change interrupt. You could select an input pin on port A and then write your ISR around that. And in the ISR you could use timer to check how much time passed from one change to another. Wink
arunkish
PostPosted: Tue Apr 28, 2009 8:01 pm     Reply with quote
Hi Bungee
I dont use RS232 protocol for receiving the data. I'm not much familiar with assembly and as I said you the posted assembly code works perfectly, but the code that I tried did not work. Please help!!
bungee-
PostPosted: Wed Apr 29, 2009 1:15 am     Reply with quote
Well as I said in first post. You used delay in interrupt routine, but you don't use it in the assembly.
Why would you like to rewrite it to the CCS in the first place if the assembly works for you?
