Surprizing PCD V4.091 assembly code
FvM
PostPosted: Fri Apr 24, 2009 12:03 am     Reply with quote
Thanks to krogers for supplying the source. You may want to repeat with buffer [4096] !
....................    char buffer[64] = {0};
003AA:  CLR     808
003AC:  CLR     80A
003AE:  CLR     80C
003B0:  CLR     80E
003B2:  CLR     810
003B4:  CLR     812
003B6:  CLR     814
003B8:  CLR     816
003BA:  CLR     818
003BC:  CLR     81A
003BE:  CLR     81C
003C0:  CLR     81E
003C2:  CLR     820
003C4:  CLR     822
003C6:  CLR     824
003C8:  CLR     826
003CA:  CLR     828
003CC:  CLR     82A
003CE:  CLR     82C
003D0:  CLR     82E
003D2:  CLR     830
003D4:  CLR     832
003D6:  CLR     834
003D8:  CLR     836
003DA:  CLR     838
003DC:  CLR     83A
003DE:  CLR     83C
003E0:  CLR     83E
003E2:  CLR     840
003E4:  CLR     842
003E6:  CLR     844
003E8:  CLR     846
PostPosted: Fri Apr 24, 2009 7:03 am     Reply with quote
The code is inefficient, but is according to the ANSI C89 and ISO C99 standards as far as I can see.
Here a quote from the ISO/IEC 9899 chapter 6.7.8
27 EXAMPLE 4 The declaration
int z[4][3] = {
{1},{2},{3},{4}
initializes the first column of z as specified and initializes the rest with zeros.
This same example is in ANSI C89, chapter 3.5.7
It wouldn't hurt though to ask CCS for implementing a more efficient implementation...
FvM
PostPosted: Fri Apr 24, 2009 9:19 am     Reply with quote
Yes, no doubt about it.
Also considering the buffer[4096] case, you may want to call it ridiculous. I would actually expect a code similar to memset(), except for the superfluous MOV #0,W2.
04C30:  MOV     #1816,W1
04C32:  MOV     #0,W2
04C34:  REPEAT  #7
04C36:  CLR.B   [W1++]
