Hi guys,
I have 2 sensor nodes that will send the signal to the base station board. If i want to know the node_id, what should i do?
Am i need to define the id for every node or every node had the unique id and i just call it? The sensor node using PIC 16F886 and base station board using 18F4620.
If there is anyone who can help this would be greatly appreciate.
Posted: Mon Apr 20, 2009 11:47 am
Post the bus type and/or communication protocol that you are using.
Also post the manufacturer and part numbers of your boards.
adia Guest
Posted: Tue Apr 21, 2009 10:02 pm
Thanks for the response. Actually I'm new in this area, and try my best to post the details.
I'm using EmberZNet Serial Protocol. CCS Wireless (Ember). But I don't know where to get the part number.
